Need Some Input Re: Recovery strap
MikeinCincy
I am very new to the off-roading scene and I was wondering if you guys could point me in the right direction. I am looking to buy a rope, or strap, or chain, I don't even know what they're called, to keep in my 4Runner in case I ever need to be pulled out or I need to pull someone else out. Cost is not really a constraint. I'm pretty embarassed to ask this question, but I definitely appreciate any and all input. Thanks.
Mike
I did a Google search and I found a "snatch strap" made by ARB. It was like $70 if I recall correctly. The only question I have is, how does it attached to the vehicle of it has loops instead of hooks?
I have a similar question, and I've read through a lot of the info on recovery, but I guess I'm missing something that must be obvious to others.
So if I'm being pulled from the back, I can attach the recovery strap to a receiver shackle in the tow hitch. Ok, makes sense.
Now for the front, I have two stout looking closed hoops on the front of my 4runner. If I am being pulled from the front, do I attach to these, and how? I know a knot is very bad, and a loop through can only be done on one end. Do I use a d-ring shackle to attach a recovery strap to one of these? There is one of these hoops on the back left too, can I use a d-ring shackle to attach a strap to this instead of the receiver shackle in the tow hitch? Thanks!
Get a couple of D shackles
most hard ware stores carry them, just make sure they are rated to about 1 or 2 tons, dont get small ones - use the D shackle to attach the snach or heavy chain to the truck
