Need to replace rear wheel bearings
ShannanC
Member
Anyone ever heard of Febest?
I came across this on Amazon: Febest - Toyota Rear Wheel Bearing Repair Kit (40X90X28X23) - Oem: 90301-88077.
I was wondering if anyone had used this kit.
And how about this one: Beck Arnley 051-4272 Wheel Bearing Kit?
Part of Amazon says that the Beck Arnley is compatible and another part says it isn't.
Looking at that picture, that bearing looks to be for the 01-02 identified by the protruding inner race. Also, those larger gaskets are somewhat unnecessary even though the OEM part breakdown shows them. One of those larger gaskets goes between the brake drum and hub. I wonder if anyone uses that gasket.
I would use OEM parts for this job. You could probably find the OEM bearing, inner seal, c-clip, and one retainer, (all you need for this job) for very close to a $100 per axle - the price for this kit.
