New and used timing Belt Kit parts 3rd Gen $75 shipped
Stretch1100
New and used timing Belt Kit parts 1996-2002 Toyota 4 Runner V6 3.4L 5VZFE
Kit Contents:
Water Pump (factory oem good bearing used) THIS ONE HAS THE WATER PUMP HAS THE OIL COOLER PIPE AT THE THERMOSTAT
Timing Belt Idler Bearing Upper (factory oem good used) missing rubber cap just reuse yours if in good condition Timing Belt Tensioner Hydraulic (factory oem good used)
Thermostat (factory oem good used)
Thermostat O-Ring (Brand new in bag)
Air Conditioning Belt (used no cracks or signs of wear)
Alternator Belt (used no cracks or signs of wear)
Power Steering Belt (used no cracks or signs of wear)
Crankshaft Seal Front (new THO)
2-Camshaft Seals (new Ishino)
Upper and Lower Radiator Hoses (factory oem good used)
Cooling Fan Clutch Bearing Bracket (factory oem good used, this part alone goes for $130 at Autozone and this stock one still has a good bearing in it)
Fits following applications:
1996-2002 Toyota 4-Runner V6 3.4L 5VZFE
How many miles are on the parts?
I have no idea. I just bought the truck and did the timing belt maintenance as I bought a kit with all the parts. As I started to tear into it I found that it looked to have already been done not to many years ago. Bearings in all parts are good.
