New Dasaita G12 for the 5th Gen 4Runner
gibburnz
Hey folks. Dasaita just released their new G12 head unit that does all 5th Gen 4Runners from 2010-2023. Check out my latest YouTube video on it and leave comments.
Dasaita G12 for the 5th Gen 4Runner - YouTube
If you wind up wanting to buy this model or any other model like the Vivid 11, enter RG8 at the time of checkout for 8% off.
Dasaita Android Car Stereo
What is the wattage on the head unit? Can’t find that or the other output options on the spec sheet. May have missed it.
It looks nice
Looks like the 2021+ head unit
He says it has HDMI thats good, so it should be an HD screen.
Boy i bet thats going to REALLY make the side and backup cameras look clearer.
I just installed the G12 couple of weeks ago. Everything worked fine except my steering wheel controls had no response to the head unit. I tried different CANBUS configurations, rebooting, made sure all the connections were seated, even went on the Dasaita forum to find some solutions. Then I ran across a thread on that forum that a member had the same symptoms until he found the SWC connector had bent pins.
Check my SWC connector and sure enough, two pins were bent while it was seated to the unit. Straighten them out and tried different configurations and all worked fine afterwards.
So just be sure to make sure all the connector pins are aligned correctly when seating them in or it can cause major headaches.
Can't leave comments because you turned comments off on youtube.
That cant be good...........
Normally this happens when the comment section is going a different direction than the poster intended, typically hate and angst from the product not doing as advertised. Care to share what your comments were going to be?
