New guy here pics and a problem lol
4runnin83
Hey guys, I have a 93 4x4 4inch lift 33s. I'm trying to seafoam, and all the posts I found say to use the hose from the master cylinder, when I take it off to introduce the sea foam the engine dies... Any ideas?
IMG_1408.jpg~original
IMG_8003.jpg~original
ya you have to use a different hose best idea is find a hose that is after the tb opening and go from there i cant rember off the top of my head as i dont have my 3.slow anymore but there is a hose that should be vacum pulled after it put a picture up and i mite beable to help u alittle more
Any help is appreciated lol
3vz_engine_front.jpg~original
also rite by the a on the manifold there is a vacum hose u can use you just need to get a hose to hook to the port it un hooks from and it should work
i think the problem is your letting it suck up too much at a time. helps to turn up the rev to like 1500 before starting to seafoam
As soon as I disconnect it from the master cylinder, it stalls, before I can even pout in the SF :(
yea that causes a huge vac leak. well you see the three little tiny hoses right above the throttle body (where the rubber intake boot hooks up to) use any one of those three hoses. they should be small enough to not cause a stall. plus turn up your idle before doing seafoam. i set it around 1200-1500. dont let it suck up too much at a time. dont wanna hydro lock the motor.
Thanks toyo. :)
I have been wanting to paint my bumpers black. Would love to hear what you did. I want something that wont come off easy.
All I did was clean them with mineral spirits, did a light sand w/ 2000 grit sand paper, and spray painted with rustoleum gloss paint. They came out good, you almost can't see the big ass dent in the front :)
The key is how you spray, you need to do sweeping light strokes I guess is the best way to describe it. Very light. Spray from about 7-8 inches away.
