New guy here
WOJO
Hopefully someone can help here. I just got done replacing the valve cover gaskets and while I was there I replaced the o-rings on the injectors. It started afterward with a little help then seemed to settle in. Turned it off. Started a few minutes later for a test drive. Backed down the driveway and it died. Not it will not start. At a loss here. Help please..
I'm sure someone here could help but first you need to give a better explanation. What motor is it? Is it just cranking and not firing, does it turn over? Let's hear some specifics.
It's a 93 3.0. It cranks fine but will not start. It started and ran when I finished, ran for a bit and then just died when I went to take it for a test drive. I have not checked for spark yet. I am not sure if the fuel pump is coming on. I can't hear it. This is crazy as all I did was change gaskets and o-rings.
Well fuel air and spark are needed, so you also need to check for fuel. Report back because it could be a few different sensors causing your issue.
So I disconnected the Mass Air Flow sensor and it would run for a few seconds then die. Plug it back in and it would not start, only crank. Safe to say it is bad??
Very well could be the culprit. I'm not sure how to test it with a multi meter, but I'm sure you could find something on the internet.
Ambrose67
