New Member Needs Tire Info
Dunkster7
Hello all,
I am a new member here and I am in the process of buying some new tires and was wondering about size. I have been looking at the Goodrich size chart and I came accross the LT265/75 R 16/D and was wondering if anyone here is running these? I have heard they are the largest size that won't rub on a stock 4Runner? Any help for the rookie would be appreciated. Thanks
Dunkster
Dunk,
Yes, you're right...the TALLEST tire that will not rub is: 265/75/16. You can also go for 275/70/16 (which is slightly shorter--in diameter).
BFG AT KO is a great choice. They also come in stock size. I had both. The 265/75/16 did cause noticeable power loss...thus, i went back to stock size.
Go to this sub-forum to read more about tires (many threads on this topic):
http://www.toyota-4runner.org/forumdisplay.php?s=&forumid=8
Hope this helps.
275/70 R 16
Thai,
Thanks for the help! I didn't know the 275/70 R16's would fit without rubbing? I may actually opt for that size. I basically would like as much surface area as I can get. With height you always give up noticeable performance as you already found out. Cool forum!
Dunk
ghengiskhan
