New member with 147k maintenance questions
ZoomSpeed
Hey guys, I just bought a 2001 SR5 supercharged 4wd with 147k miles on it. Being such a high mileage car what kind of maintenance should I start with?
So far on my list I just have: change all fluids, spark plugs, spark plug wires, and air filter. What else should I do or at least check on? Brakes? Shocks? Belts? Valve adjustment?
Thanks for any help guys
when was timing belt/water pump last changed? fuel filter, do the shocks need to be replaced (push down on front of car... does it bounce more than 1/2 times??)...
I don't know when/if the timing belt/water pump was changed. I'll bug the dealer about it and see if they know. If they have no clue would it be best to go ahead and ahve it done?
Where is the fuel filter on this car? Is it easy to change?
They said that the supercharger belt, timing belt, and waterpump were changed at 98k miles.
well that means you should be good until around 200k miles... i believe the 3rd gen 4runner has 100k mile intervals for timing belt.. not 100% positive though.
