New problem (sort of)
FormerJeeper
I have spent some time searching and haven't really seen anything that addresses this issue.
Problem: Rear window on my 95 goes up and down all day long with the console switch. Key switch will roll it down fine, but will either not roll it up at all, or it'll come up about 2", stop, go maybe another 1/2", then nothing.
It's not the integration relay, we tried several at the Toyota junkyard here in town and they all did exactly the same thing. Which leads me to believe that its not the module. Anybody have any experience with this?
I have cleaned and lubed everything possible inside and out, next step would be to Ohm out each and every wire back there...not something I really wish to do.
Any help would be appreciated! :shrug:
is the window coming off the tracks? My passenger window comes off the tracks on the way down and then doesn't want to role back up properly.
Have you replaced the switch itself in the key cylinder? That was the culprit on both my back passenger windows with similar symptoms.
No, it seems to be on the tracks fine, as it will roll up with the console switch without hesitation. I did replace the actual switch on the key cylinder once, it was doing the same thing before. So unless that 2nd switch has the same problem...Grr. Electrical demons are the worst!
These switches do fail often. I keep a few extras for the doors (when I have them on) on the garage. I went to the local pull and pay and picked them up for less than $10 for 4.
Mike Sargent
