New Products & Prototyping | Victory 4x4
Victory 4x4
Official Vendor
We have a few new 3rd Gen parts coming soon. Roof Rack, Door MOLLE Panels, and Center Console MOLLE Panels.
More to come! What else are you waiting for?
Finally!! A lot of the newer fabrication shops don’t have the 3rd gens in mind but there are still plenty of them out there! Thank you guys.
If you can do metal work you would be able to sell a ton of skid plates for our 3td gens. I'm not talking about the 100lb plus Boulder guards, something lightweight like the Taco skid, something that offers some protection against debris getting into the engine compartment. I got in an accidental about 10 years ago and I haven't been able to find a replacement.
The roof rack looks awesome, and the center console MOLLE will be on my short list for sure.
Awesome to still have aftermarket support for these rigs.
Thank you.
Where do we sign up for the testing/ early purchases? I have been looking for the center console setup for a while now. The doors are even better!
Rear Window Molle Panels that don't stick out 3 inches into the compartment.
I want something that tucks up inside the window opening instead of sticking out from the panel so far....Ideally it would be nearly flush with the window opening in the trim panel....
Rear Window MOLLE Panels are in the works, along with our cargo basket!
Accessory brackets for engine bay (fuse block holder, emissions/engine accessory relocation, etc.). Light bar mounts for stock bumpers (there are two large bolts below the bumper that would be perfect for those not running aftermarket bumpers).
Rear shock guards/skid plates that protect those of us who may be running crazy expensive kings/ADS/Icons etc out back. The way the 3rd gens are set up, the shock shaft is just exposed to rocks and whatever else comes at them
Another idea is a lightweight steel (thin steel should work well) skid plate modeled after the OEM plastic/fiber board piece that covers the fuel filter area on the driver's side.
Every OEM piece I've seen is cracked, or missing altogether.
This metal skid would serve to keep mud and debris off of the trans linkages and fuel filter areas, and would really clean up the underside.
erinobr2000
