New project
Rear shocks changed to King remote resi's:
I was in a hurry to get it finished so I forgot to take pictures before the tires went on. The lower mount on the shock wouldn't fit onto the lower shock mount stud so I had to bore out the center a bit to make it larger.
Here they are next to the Icons:
DSC00489.jpg~original
DSC00490.jpg~original
DSC00491.jpg~original
DSC00492.jpg~original
DSC00493.jpg~original
Budbuilt front skid:
DSC00496.jpg~original
DSC00498.jpg~original
_DSC1707.jpg~original
My stock skid was pretty beat up, and here's where the sway bar was rubbing it under full compression
DSC00504.jpg~original
I thought you were going to get the ENTIRE lower body armor.
How much did this set you back?
And how much for the entire lower body armor?
I felt that full armor is overkill for my needs and will just weigh me down with how heavy they are.
Their 4 piece set it over a grand and their 5 piece is about 1400.
I really want a budbuilt skid set but the price (and life's other expenses) is seriously slowing me down on obtaining it...
I would advise against adding that much weight if you plan on a spacer lift as noted in your signature. Their thinner skids might be light enough though. The difference between my skid and their thinner one is 7 lbs (23 vs. 30) so an entire kit would be considerably lighter.
Josh,
You !@#$%^&*() hahaha...looks nice.
I noticed your Weathertech sticker on your Cargo Liner is upsidedown...mine is not.
• Why would you need a fridge in your 4Runner?
• How long does it take to chill a drink?
• And what's the capacity of that fridge?
• Because I want one
• It got down to it's target temp (35 degrees) in less than an hour. It chills as any other fridge does.
• 50 QTs (72 soda cans)
12v... I have the outlet wired for constant power, now I just need to hook up the dual battery. Right now it's running off of my stock battery.
Do you have write up for constant power? Constant power for stock outlet or after market. I plan to install an extra constant power outlet but don't know where to tap the power to.
tuṣṭāva
