New (to me) 1995, seeking knowledge...
Soren
Hi Everyone,
Just bought a 1995 SR5 3.0 4x4 manual transmission. I have a few questions that I hope people here can help me with.
Vehicle has 209k miles. A gross polluter when I bought it, as the seller is, uh, not very car savvy, and attempted to smog it with a bad misfire. Bought it because it was a good deal, and was the best condition truck I'd seen in my price range. I've replaced one headlight bulb and one 1157. Everything else seems to work! Except for the broken power antenna.
I put in new plugs, wires, cap, and rotor. Plugs were gapped (or eroded...) at about .055"-.060" Cap and rotor were in poor condition. Two wires were damaged during removal (my bad, but I couldn't find my boot pliers, and the caps were really well bonded to the plugs).
I also put in some seafoam in case it was a dirty injector (truck had sat for ~6 months), so I'm not completely sure what fixed it. I suspect it was electrical. Yes, a "parts shotgun" approach, which is not my normal style, but I had a clock running and was willing to spend up a little to get it smogged asap.
No smoke. Appears to use little or no oil - just did a 475 mile trip from the SF bay area to Tahoe. 17.6 mpg uphill, 19.3 mpg downhill. Seems typical. This with a thule top box.
Questions:
1) Shocks. I'm likely considering:
Bilstein 4600/B6 (~$75 ea tire rack)
Koni adjustable (~$100 ea tire rack)
Rancho 9000 (~$110 various online)
Other suggestions welcome!
2) Tires. I'm unlikely to do any hard-core off-roading. I do expect some snow and some dirt roads. I took my old 2wd Mazda B2000 onto a lot of dirt roads with a Michelin LT tire - I think it had a M+S rating, but was really a highway tread. I'm looking for a similar tire. M+S rating to get past chain control, but mostly a long wearing, QUIET, highway tire. The current tires are a Big-O all terrain tire. Almost worn out. Noisy. Lots of cogging, I keep thinking the engine has quit when it stops rolling because it gets so quiet.
3) Hitch. Cannot believe it, but I must have the only gen 2 4runner on the planet that does not have a hitch. Looking at the Curt for $150 or so. Maybe look for a factory hitch from a wrecking yard? Anything to consider here besides price and obvious fitment issues? I'm unlikely to use tires larger than 31".
4) Trailer wiring. Only thing I've seen splices in. Is there a plug in harness available? I can do the splice, and do it right, but I just hate to cut the factory harness. If I have to splice, I'll cut the wires in the tail lights, past the main harness. Don't care if I have to put in another grommet.
5) This should probably have been item (1). I've got a minor valve tap or exhaust leak. Didn't notice it on the test drive - though the misfire made focusing on anything else difficult. I hear it now, and it seems to get a little louder with throttle, so I'm thinking exhaust leak. Any comments, suggestions, warnings, common failures, etc. on this issue?
6) Radiator, water pump, and timing belt were supposedly replaced less than 20k miles ago. Since it's a non-interference engine, I'll probably assume this to be true. I can tell that the radiator and (I think) water pump are newer. Though this is a minor red flag given item (5)...
7) Anything else to watch for? Truck drives great (allowing for the poor shocks and worn A/T tires)!
Thanks in advance!
--Soren
I bought some Rancho 9000's for my ride. I am not impressed at all.
Whoever I had it from cranked up the torsion bars to raise the front end and it made it ride terrible. I bought some ball joint spacers and lowered the torsion bar setting and the ride greatly improved. I am still not super happy with the ride.
If I had it to do over, I would just buy the whole Old Man Emu kit and replace the springs and use their shocks.
Hey thanks for the word on the Rancho's.
The OM Emu kit is probably overkill, and my T4R doesn't show on their website, but I'd never heard of them, and new info is good info!
--Soren
Welcome! I too have a 95 (140k miles, auto though) and experienced similar issues. Also repaired or replaced many of the same components!
-what's broken exactly? Could be an easy cheap fix (with oem parts even!). lots of threads here and on yota tech that cover it.
Questions:
1) Shocks.
-I just put on the bilsteins on all four corners. That coupled with moog rear springs helped a lot with the ride/cornering quality. The coils reduced most of the rear sag.
2) Tires.
-I put on a set of General Grabber AT2's (stock rim, 31x10.5 I believe). Pretty happy with the results. I do mostly city driving, some basic trails (rare). I bought it mostly for the inclement weather (Boston/New England) and because they look cool! ha. Tip, make sure where the rim meets the tire is cleaned of corrosion. I had a bunch, which prevented the tires from maintaining consistent psi.
3) Hitch
-Would like to see how you make out here. I too do not have a hitch and am looking for one. Not just to tow, but for a nice recovery point with a decent D ring and strap.
4) Trailer wiring.
-Curious here as well!
-check to see if your truck was involved in the head gasket recall
-check to see if your truck was involved in the steering rod relay recall. toyota replaced my steering rod relay last year. if your truck is under that recall campaign, I'd suggest replacing the tires then getting that done. free alignment!
-interior lights! I just changed a bunch, including the hvac, gear shift indicator and map lights. i'd recommend it if they're burned out.
-lastly, check your spare tire to see the condition it is in. also check to see if oyu have all the jack components in your truck, to replace a flat.
If your on a budget can I suggest DT shocks from lowrangeoffroad? I put those in mine and love them, Obviously not as quality as others out there but for the price.... I think its spelled Doetsch Tech. And for a cheaper quality tire for light wheeling I used to run Falken Wildpeaks. Did quite well in the sand before I went with BFG's.
Hi Soren
Glad to hear you scored a decent 2nd Gen; lucky you with the manual transmission.
You state your mileage figures pretty specifically. My '94 has a wildly, but still usably, inaccurate fuel gauge. On road trips, I carry Jerry cans so I was never too worried about inaccurate readings...they seem to average out over time and conditions. Are you calculating your mileage or refilling so often you know exactly what amount of fuel you used?
I've taken mine on a few overlandings and it has worked just fine.
Best Regards,
CentCalKid aka Chris
--Soren
Go to Toytec's site to see the Old Man Emu shocks
Hi Soren, welcome to the community. I can take a shot at a few of your questions.
2) Prior to buying BFG K02's for my truck it had a set of worn Michelin LTX ATs. They were substantially more mild than the BFGs and still held up in the dirt. Super quiet and good highway ride as well. I think these would fit your goals well. Also good idea keeping it to 31x10.50 as this is the most tire you can easily fit in the spare tire area under the truck.
3) Mine didn't come with a hitch either so you're not alone! I know there are a variety of sellers, I had also considered pulling a junkyard one.
7) With that many miles you might consider doing a full fluid change. I recently changed the fluid in my manual transmission and transfer case and the shifts are much smoother. Next on the list are the front and rear diffs. You really have no way of knowing when the last time that was done was and I'm betting the manual transmission fluid has never been changed.
Look around carefully underneath the rear frame and bumper. There may be a trailer wiring harness tucked up in there somewhere, unterminated. The fact that you have no hitch may mean they also didn't include the wiring, but it's worth a look. If it's there, it will also have the converter box to go from separate turn signals/brake lights to the combinations found on trailers. It'll save you a lot of work.
seltzernator
