New to me 2002 SR5
ITWrencher
I just picked up a 2002 SR5 with 215k on it. I had to drive 2.5 hrs. to look at it in the NY/NJ area from CT. Doing that drive with a trailer across the GWB was no picnic and then coming home on I-95 through Fairfield county was like having toothpicks shoved under your fingernails. But I digress.
So I just started really looking this thing over because when your 2.5 hrs. from home you just don’t seem to be able to go through it really thoroughly sitting on a side street in the bitter cold. So what looked like a super clean body turns out to be not so much. It isn’t horrible but not what I saw when initially inspecting it.
There is chrome bubbling on the front bumper, paint bubbling on the hood leading edge and paint bubbling along the windshield roofline. And how about that windshield. I noticed yesterday that it is loaded with some kind of RTV or similar sealer all along the top edge and the trim that goes around the outer perimeter of the windshield is MIA? So I lowered the spare tire after that and the thing looks like it will shatter into a million pieces if you hit it with a hammer, completely unusable (rust).
I have another set of OEM wheels and tires so not a huge deal. The next thing I notice is that the "boom boom" stereo that is installed has an external amplifier that is lying on the floor in the rear hatch area covered by the rear luggage rug. This I saw when I looked at it. It also has a subwoofer mounted in the rear passenger side storage compartment so there is no place to store any emergency equipment?
Moving on to the front passenger area I find that the clock isn’t working (not uncommon) and that when the radio turns on the antenna does raise up. So I took that part of the dash apart to remove the clock and fix it as well as check to see if the antenna is connected. Why do people cut the factory harnesses………? I haven’t installed a stereo in quite a few years but I believe there are aftermarket interface harnesses you can buy that make this a plug and play deal correct me if I am wrong?
So I also found phantom wires from a previously installed accessory? Not sure what it was but seems like it might have been some type of communications device? And I found some cut wires that were wrapped half assed with electrical tape? No clue what they are for but I suppose I will figure it out sooner or later. Worst case scenario I can pull apart my other 2002 Sport SR5 and see where those couple wires go.
Yesterday I pulled the dash panel out to get better access to everything. It was one of the easiest dash panels I have ever removed! I found the antenna power wires from the auto antenna relay inside the harness but have not found where they were cut? Today I am going to pull the blower motor out and see if I find anything behind there. If not I will just splice into the harness the new wires I connected to the power antenna.
OK end of my rant. All of this is my own damn fault for not taking more time to inspect this vehicle before pulling the trigger. But when you are 2.5 hrs. from home the prospect of driving home empty handed weighs on you a lot. Lesson learned next time take more time looking over the vehicle and be ready to say thanks no thanks and leave.
If that is the biggest issue with the rig - then you are pretty ahead of the curve...
At this age, almost every one of these is going to have a laundry list of issues.
But nothing the wallet won't fix, right??
As far as the antenna - do you really need it? I took the wiring from the rear glass antenna and
spliced it into the now disconnected power one and it works well enough. Spotify for everything else.
Most of the ones I bought had rust holes in the frames...LOL.. In the northeast rust belt, that is really in excellent condition considering the rockers and frame are still together. :-) I am sure you can fix most of those issues. The chrome bumpers are all junk by this time. As long as the major parts are good. You be able to fix it up.. :-)
Nice! I have a 2002 SR5 as well. As long as the frame is in good shape, the rest can be fixed. The list of stuff I've done in the last two years is pretty long, but I wanted it to be bulletproof and reliable on a long trip from NY to the top of Alaska. It was except the power antenna stopped working. I replaced it with a none power one from a 1st gen Tacoma.
I actually fixed the antenna! The previous owner for some unknown idiotic reason cut the wires/harness to the power antenna and attempted to reconnect it to wires that don't allow it to work? I spliced 2 new wires into the wires that remained and ran them to the dash area where the radio lives. Then I located the two wires that it was supposed to be connected to on the Auto Antenna Relay and voila it started working again. Just ordered all new brake parts yesterday. Went with a Powerstop kit from Rock Auto that has a $110 rebate currently. Went with the drilled and slotted discs in the front and regular drums etc. in the back. Just hoping the calipers are all good to go? Gambled that they are still serviceable to try and save a little money as I am hemorrhaging cash with both of my 2002 Runner's currently. Had to order all the OEM parts to do the head gaskets again that I just did in June which is my fault entirely.
I too recently purchased an '02 SR5, and live in Westchester county, NY
I will be replacing my front bumper pretty soon; as soon as my SRQ off-road front bumper comes in. Happy to part with it, and my running boards too as I also ordered rock sliders.
While you have the dash apart, consider replacing the dash light bulbs with LED type, and only buy new ones from superbrightleds.com
There is a post on which ones to use, the '02 has a few differences from prior years.
Good luck,
-mike
Good luck,
-mike
Mike I am a Michael too! My bumper is a chrome job and is starting to rust through. I would be super appreciative to get your bumper. I already have running boards so won’t need them. Thanks for the offer I am not that far from Westchester in central CT.
Good luck,
-mike
Hey I tried sending you a private message but it said you don’t receive them or can’t receive them or something?
He can't send or receive PMs because he only has 2 posts to date, the rules are you have to have a minimum of 15 posts to be able to start a topic or to do PMs.
This was started a while back to try and stop SPAMMERS/BOTS.
But the fact that you quoted him should notify him and direct him back here.
OK that's kind of what I was thinking.
Hey, just seeing this now. Still waiting on my new front bumper from SRQ Fabrications. I see you're not too far away. I will also be parting with my in -excellent condition roof rack.
I'll try to send you a DM...
-mike
I'll post a few more times so that I can get past this newbie restriction...
Just an FYI, I haven't yet recd my SRQ Fab front bumper...
Hello;
I am now able to send/recv private messages (still a rookie), and I am in touch with ITWrencher for my front bumper. I still have a pair of running boards in case anyone else wants them.
-mike
Hey, 1996 here, also another north easterner.
If you haven't gotten a bumper yet, I think I learned this here, but no matter, it's worth re-sharing.
The ARB bumpers (so I'm told) are the only "off road" bumper made for our rigs, that meets or exceeds all traffic safety standards.
All the rest are "off road" designation, so they can legally be sold since no high speed traffic accidents happen "off road".
Perhaps that has changed with some brand or another, I'm not casting stones, but since mine sees more road miles than off road, and I already hit a deer and wasted the front end pre ARB, I'm disinclined to have my front end take it worse, should the unthinkable happen again.
On the rot/rust? Depending on how deep you're going, there a lot of places doing moderately priced natural oil based undercoating now.
I got mine NH Oiled, for $250, they drilled the doors, shot in there, did the whole underside, shot in the frame etc. Recoats are $50.
Being dyed black, it looks way better, but the stuff also does a nice job of pushing off flaking rust, and preventing further issues, for a lot less than typical chain store style, jump through hoops to maintain warranty, type undercoatings.
Enjoy the new toy!
charlesz
