New to me 4th Gen issue. Youtube included
soloone
I figure this post was okay here do it being 4th gen specific, If not Mods please delete.
I think...
Just picked up the 2007 Limited V6. It was doing this during my test drive and allowed me a negotiate a lower price. I am having problem and in the manual i downloaded i cant find this specific part. As you can see in the Video below, the Compressor or pump (Gold mechanism)) seems to be on a constant cycle. I think it is the break booster that should cycle when pressure is needed... but not every 5 seconds.
Any clue to what the part is?
Better question - Any clue on what the solution is?
I think...
well....if that master cylindervis bad, expensive! you may be able to find a used one cheap though. why is your brake pedal squeaking like that???
It doesn't seem to be the Master cylinder as in what i believe to me the master assembly in the white item in the picture.
mastercyl02_1-jpg.442110
Rather the Gold cylinder to the left is whats making the noise and cycling. IN the second video (in the Cab) the truck is at idol. I am assuming the in cabin noise is the same as the cycle. I am not as big of a mechanical Newb as I sound here I swear. Thanks for the help guys.
The brakes are hydraulic on our trucks and that cylinder us boosting the pressure. Either you have a leak, which you would figure out quick, or something in that assembly is going bad.
Sent from the drivers seat of my 05 4runner.
Yes, I do understand. Pressure seems to be fine. I don't feel a change in pressure to kick on the booster. For example, i would assume that after a few hard slams on the brake pedal it would kick on and not on a continue cycle that makes me think the control unit is acting up.
Crookedcat
