New to the forum, got my 4Runner back
marcdc
Hey Guys,
I've been poking around on the forum, doing some research for my 1998 4Runner Limited. This was actually my first car when I was 16 (in 1998... 15 years, seems like yesterday), and it had been passed down to my middle brother and my youngest brother. Since then, I went down a bit of a different path, sticking to German cars and getting into auto racing. When I moved to NYC for work, I sold my cars (not worth keeping them while I'm in the city) and have been without one since the beginning of 2011.
When I moved out of Manhattan and into Brooklyn (Williamsburg area), I decided it was time for a car again, as I was getting sick of Zipcar. I thought this would be the perfect opportunity to restore the truck, as it has taken quite the beating over the past 15 years.
First order of business was redoing the interior. I found a shop in Vienna, VA (the truck was in MD sitting at my parent's house for the past 5 years, rarely being used) called Lim's. They redid the front two seats, added heated seats to both fronts, redid the center console, the rear bench and the steering wheel. Is it showroom quality? Absolutely not. But it's much better than it was, and the steering wheel (tho not great) is no longer disgusting.
Next was getting the audio system back up to snuff, but I won't bore you with the details on that.
About 2 years ago my youngest brother put a full Downey Off-road suspension on the truck. From what I gathered they had a decent reputation, but are now out of business.
Below are some pics of the truck as it stands now:
I want to get rid of the front bumper and brush bar and get something from either Shrockworks or Demello
EV9f7JM1CyuZxnrg
I'd like to do a new rear bumper too, but it's not a priority
7yX5FnTgGEZcjsz
RvQkT01iaFXk4EA
front seats came out ok, stoked we were able to add padding. you could feel the metal bars under your ass before this
7oDN1OZXLJiY0EY
rears came out pretty well too
KUce9oOQH8XtnLT
steering isn't perfect, but it feels nice and is much better than before. no more need for a steering wheel cover
ESwOJnjfeK7YUrdq
nav install (pioneer 940bt)
i6L984yi5RA9fL
rear box that houses 2 amps and a JL Audio W6
27eJkRR1kRo52SaU
The big problem I'm running into is I don't know of any good shops in the NYC area. There's a place that I found called RMS Offroad, but I have no idea if they do quality work, nor what their reputation is. I'd also like someone to take a look at the suspension that was installed and give me their thoughts on it. It doesn't look like the car is any higher than stock, and I really don't know what's been installed. Does anyone here know of any good shops in the NY area? I'm willing to drive a bit.
Anyways, just wanted to introduce myself here. It's been a long time since I've owned this truck and I'm excited to get back into it. I certainly have a lot of catching up to do, but I'm sure it's gonna be a fun journey.
Truck looks great the interior is mint!! I hear ya on the steering wheel mine is all worn down but that'll probably be the last thing i do on the truck. Keep us updated.....
you can see my sticky wheel here....
DSC_0861 by BryanHynes, on Flickr
and old seats...
DSC_0860 by BryanHynes, on Flickr
do you mind me asking how much the reupholster job costed you?
happen to have any build specs/details for your speaker box?
not a ton. it's built from MDF and size was my biggest concern. I wanted something small enough that wouldnt be obstrusive, but large enough to house my monoblock PPI amp and my 4 channel PPI amp, as well as one of my 12in W6s. I made the sure the grating on top of the sub was strong enough to handle whatever I put on top of it.
i used to have 4 JL Audio W6s in the rear, with carpeted fire escape grating on top of them. but im no longer 16, and have no need for that much bass. this is just enough to round things out nicely
Sure, so the total cost was around $2,100... but becuase of the headaches we had the first time around, I haven't paid the balance of it yet. I gave him a $1,500 deposit, and am not sure how I'm going to handle the rest yet.
Nice job ! You can take some pics of the suspension and maybe we can help you out ?Other then that , if it rides good and does not make any weird noises then you should be good to go!
From the picture it looks like you have a spacer lift up front.
get some of that $10 forever black auto dye from amazon and hit that rear bumper cap with it. will make it look a TON better particularly since you have a black 4runner already.
great idea, thanks for the tip. does that stuff actually last or do you have to reapply often?
awesome. yea, ill try to take pics of the suspension and post them here later tonight... you guys would definitely know better than i would. the rear was sagging from general wear and tear, as well as having a couple hundred pounds of audio equipment and a the custom box in the trunk. that was the impetus for putting the downey equipment on here.
no weird noises which is good. handling is ok, but im a bit jaded on that front. i feel like i need some beefier sway bars, and the tires on here, tho m&t, are dogshit in the rain.
i'll have to get back with you on my experience since i just dyed everything.
a couple others on here have reviewed it and said its still looking very black a couple years after applying it.
That's awesome that it's been in the family for 14 or 15 years. How many miles does it have?
Funny thing about that. So the truck has 164,000 miles on it. However, due to it not being driven much, as well as some less than stellar maintenance by a shady shop in Texas (youngest bro went to UT-Austin) while the car was down there, caused the engine to seize up about two months ago. It was a headache, and four engines later we finally found a stellar replacement. Super clean engine, only 72k miles on it, replaced the spark plugs, timing belt and water pump. Works great and sounds great
