***NEW Toytec "Superflex" rear coils***
Hopefully we get a time frame or something soon, I don't want to force myself to buy any Landcruiser ones for the rear. Also, if anyone reading this from Toytec has a photo of the coils on the truck when its sitting on the ground, that'd be awesome!
I also ended up going with LC 8-Wrap Coils, got them for $50 on Craigslist. Sorry Toytec.
lccoils.png~original
Nice
I have been researching new rear coils/rear spacer. I am still trying to sort out all the differences with the OME and LC coils, however it may seem to me as though these could be a good option as long as they are built for all the weight I threw on the back. You think there will be any sag with a rear bumper/spare tire swingout?
Any information on arrival?!?!
Yes they are IN STOCK!!!!
We put them in the rear of a 4Runner here that had the OME 891's and it gain 0.5 inches of lift with about 200lbs
Here are the rest of the weights we tested
3.75"+ rear lift with stock rear weight.
3.25" rear lift with 200lbs over stock rear weight.
3" rear lift with 400lbs over stock rear weight.
They also ride much smoother than the 891's!
Here is a pic of them install in the 4Runner. This truck has our front coilovers set at 3.25 inches and has about 200lbs in the rear
Are the 5125s with 8.130" of travel too short for these? (purchased w/ ultimate lift)
I'm guessing yes since they are offered with extended travel 5100s...
Edit: re-read the first page and saw those 5100s are 10" travel. Oops.
Ohhhh... :trophy:
Looks like I'm ordering some new rear coils soon... I was about to buy some trim packers to get me closer to 3.75" with the 890s. I want these more!
Yep the length of the 5150 shocks that we used to sell are the same as the 5125's so those should work fine.
Im looking to get these to replace my 890 since I have a lil lean with the ultimate lift. Were the coilovers pre-set at 3" from you guys when ordered, also will I have enough travel with using the 5125 with the superflex?
Coilovers are about 3 inches but every truck is a little different. We recommend to have a before and after measurement so you know exactly how much lift you got. If you don't have a measurement, most 3rd gens should measure 20 inches from the center of the wheel hub straight up to the fender lip in the front. The rear is closer to 20.5 inches
The 5125's will work fine with the Superflex coils
:cheers:
Dylan
