New Wiper Motor Has Smaller Sweep
Calm8809
Member
Hey guys. My rear wiper blade quite moving a couple months ago. Noticed the thread part of the shaft was broken clean off and no where to be found. It looks like it had been gone for a while with the rust and cobweb that had formed in it's place. Anyway, I just put on a replacement from the yard and I've noticed that I'm getting about a 1" smaller sweep on both sides of the wipe. It still returns properly when turned off, but during it's actual wipe is short in both directions. I was lucky enough to find the same year vehicle so I doubt I got the wrong part. Any ideas what might be going on here?
I haven't heard if that one before. Especially if it's an oem junk yard motor. Should be identical sweep
Sent from my SM-A536V using Tapatalk
1st thing i'd do is make sure u've tightened the nut down to spec, could be a little slippage between the two joints.... just a thought
Mhhh you might be on to something there. I do recall the splines not looking too great on the wiper side and I was afraid to really crank it down with the old one breaking. Maybe I'll order just that piece from the stealership. Thanks guys!
I try to find the torque spec and bring those bolts to those specs. That is if the spline are in good shape. :)
goddesszilla
