Newbie with a factory skid plate question
kball
It seems the general consensus is that the factory plates are almost useless and just get in the way for oil changes. I changed all the fluids on my 96 after I bought it in June so I R/R the skids for that. It really wasn't that bad except for one bolt that some idiot crossthreaded where the two plates bolt together. My question is, if you are not going to be doing any boulder crawling, would it be okay to just take them off and leave them off? Does anything hang down low enough to be a problem during light off roading? Has anyone done this? Notice any fuel mileage differences? I would think the skids would help air flow under the truck, which is one of the main sources of drag.
Thanks for your thoughts.
Oil can be changed with the skids on but it's a possible mess I don't want to deal with. The previous owner of mine obviously never had them taken off when serviced because there's a nice build up of sludge on them. :bravo:
what mess ? the drain plug is away from the skid plate the oil filter can be removed through the wheel well just place rags under the filter
there is a convenient hole where the drain plug is to drain without removal. the filter is also easily accessed, but my filter location may be different than the v6.
I leave mine on, it's smashed on practically because I thought it would be fun to jump my 4Runner when I had 30 inch tires on it haha. it saved me, though, my radiator was cracked through it. I can only imagine if it wasn't there. I'd have been a sad man.
I think it's even worth grabbing a Skid Row offroad plate. 4wheelparts sells them for 210+tax.
Then again, to each man his own.
I put in a ball valve with an extension hose so I can just turn the valve to drain the oil. Helps a lot with the oil mess. My skids would be a PITA to remove and reinstall since they are aftermarket.
It's hard to imagine the air resistance between the skid on or off is anything but negligable. I'd be impressed if you could find a way to even be able to accurately measure the difference. When the skid is off you still have the same amount of surface area that has to push air out of the way.
I wouldn't say the factory skids are near useless. They bend and dent easy sure but it still takes a lot of force to get through them. The radiator is very vulnerable without any skid and your transmission is cooled through the radiator. I think it would be worth buying new bolts to help with the cross threaded bolt/nut.
You can also run a synthetic like Mobile One or Amsoil so you don't have to pull the skid plate off as often. The oil is more expensive but the overall cost is less because you can safely go more miles before changing your oil. When I use Mobile One I change mine every 5000 miles but if you waited 10,000 you'd still have virtually the same wear as you would with regular dino oil changed every 3,000 miles. Synthetic is hands down a better oil. With Amsoil it's even more dramatic. With fully synthetc Amsoil you can safely go 15,000 miles between oil changes instead of every 5,000 with the Mobile One.
The skid plate takes a little more work sure but if you off road, rock crawling or not, I'd say it's well worth the extra effort.
Thanks glenyoshida
I've been reading up on synthetic oils lately. They've come a long way since the last time I looked into them. I plan on going with Mobile 1 extended performance. That way I can go a year between changes.
Thanks to everyone for their opinions!
