nice link
I use a altavita translater and this is the result:
Tire & wheel
- BF good rich A/Tko (285/75R16), opening
- 88 houses elite MAX type IV (8.5J
this is the translation
and this is what it says :
Exterior >
It does not destroy the body line of normal, furthermore installing the over fender which increases volume. Normal compared to 45mm wide the styling engenders wild atmosphere in the sporty surf. The product becomes the black gel coat finish.
The hitching member of the stainless steel make which holds practicality and fashion characteristic. Because it is collected to compact size, you can say that also those where the styling the rear is not destroyed are one of charm.
Installing the 4
Exterior >
Installing the 4
Not really sure where you are comming from?
Dude: your sig states North Cyprus. Are you really on a small island in the Mediterranean? That must be great if you are.
yes I am and it is really small compare to where you guys!!!
and in that small island it is divided so even smallerthan that!!
to be honest I thought a lot about getting 4r/surf because nearly all the 2nd and 3rd generations that we have has an engine replacement or recondittioned (Gasolin ones only)
But I liked the 4th generation so much that I am getting one.
by the way there arent any in the part that I live in!
