I searched countless times in google for '2l not working' '2l wont shift' 'bad 2l 4runner' I know how google works, thanks for the tip tho.
2L
Are your referring to 2 & L on the normal transmission shifter or 4L on the 4WD switch?
yes 2L on the transmission..shifts into all other gears fine..
Obviously you don't how this site works then.....I wasnt describing google. I was talking about this forums search function.
Your truck doesn't have "2 low" either. Just trying to help you.
Ok now it makes more sense. Are you saying you can't put the shifter in to the last spot that says 2-L?
I know how forums work, I run fancytuning.com, but to me you came off as an ass by assuming I didn't search first.
Google has every forum in the world that could potentially have a topic for an automatic not shifting into 2L..tried every keyword variation possible and didn't find a single one...this site was my last option..
So now you're telling me they just put 2L on the shifter to look pretty?
Ok now you're sounding like an ass. I'm an ase certified auto technician and was ready to offer my help.
Good luck.
Does the transmission grind or act-up otherwise? Have you tried it rolling, stopped? You said you could force it with the engine off, does it feel as if something in the tranny is binding or more in the shifter mechanism inside? My guess right now would be that something in the shifter mechanism inside has come loose or broke.
