No 4lo, not anymore.
FOYOTA86
I follow and get great info from many posts/members. I don't feel like I contribute enough...so I thought I would share my experience with a new to me 4th gen. I bought a SR5 V6 with 188K, one owner. Great truck and nothing wrong with it except the 4lo. I read all the posts about what to do, nothing! Yesterday it worked out of the blue, did nothing different with the expection of being on slight incline and slowly rolling forward, I said slowly and maybe a foot. Now it works as designed. Moral, don't give up and keep trying...it's a Yota!
I hope the same will happen for me, but I've tried A LOT with no success.
Mine wasn't working and I tried it at every red light for two days and it eventually kicked on. works like a charm now! Its a good way to get used to the "order of operations" of using 4lo too.
After messing with mine for 2 months, 4lo finally started working well. Now I'll do the diff and transfer case services. That'll get it even smoother.
Haha, are you guys not worried that after engaging 4lo you not going to get stuck there. I once engaged 4lo at the lake playing in the snow. Result: I'm driving home in 4lo at like 40 mph on highway redlining all the way. I'm afraid to touch that switch now
No fooling, with that in mind kept at it in the driveway. Only a short 1/4 mile to my mechanic if needed. Seems to be reliable working now.
Mine got stuck in 4Lo 10hrs from home. The prospect of a 20+hr drive home at redline didn't suit me so I cracked open the actuator (damaging it in the process) and shifted manually. Long story short...I eventually got a new actuator and replaced it myself. What a pain.....
The white grease inside the OEM case was the consistency of school paste. I think with age the stuff drys out and gets stiff, jamming the gears a bit. Also, the seals get kind of dry and bind on the shafts. Lastly, the electrical terminals on the motors don't actually have a crimp or spade connection (horrible design). The molded plastic basically holds the leads against the motor terminals (just mild pressure). With age I think this connection breaks down.
So, now I have a pair of spare motors (in case the one in the front diff actuator dies I have a spare, and an extra set of actuator oil seals (long story). It seems if you keep the case "exercised" at least once a month the actuator will last for decades. Neglect it.....and you're gonna be stuck.
After reading these posts I have been putting mine into 4lo on the forestry road close to my house. I go up in 2hi and coast down in 4lo and sometimes put down hill assist on when going very slow.
Yeah, I'm quite mechanically inclined as my 4Runner have never been at dealership for service in 7 years as I all do it myself. But, getting that actuator fixed is quite frightening to me from what I have read based on other's experience. I will probably do this in the next 2 years but only as splitting the case. No frigging way I will try and play with those gears falling out or risk damaging the seal. For now, I shall stick with 4hi as getting that thing unstuck is really frustrating and not happening unless you carrying around rubber mallet with you all the time.
H.Sikina
