No AC backlights, and clock display lights only on when headlights off
Troymclure
Whats up guys, I'm pretty new here, but figured maybe you could help me with a problem Ive had since I owned my 4runner.
Shortly after I got it, I installed a new headunit. While hooking up the wiring harness, I was left with two orange wires that didnt connect to the headunit but were on the conversion harness for illumination. So I figured, just connect them. Well, that sparked when I touched them so I quickly disconnected it, and saw no adverse affects. No blown fuses or anything....until I turned on my headlights.
Most of the lights that light up the ac controls do not work ever and the lights for the display that show temp, time and fuel info only works when the headlights are off. Its really odd. I also noticed that the clock display lights will work all the time when I pull the fuse for my tailights.
I really dont know what happenened or what to do. I can live with it the way it is, but Id really love to have it fixed, haha.
Any help is greatly appreciated!
Either relay or blown fuse, check the fuse for dome on engine compartment its 10 amp, also check inside for the tail, somehow its one of them.
Search around theres several people that have had this issue, I believe you fried a relay
I found one thread that I believe solved the problem. Now I need just a few bulbs as mine are blown.
On an unrelated note, were you over on acurazine? I used to have a 97 green cl and your name sounds really familiar haha
Jhunt
