No heat
Ekimrm
My blower just quit. It worked one day then the next morning it didn't. There was never a noise like something was wrong. I checked to see if there was power to it and their isn't. So I replaced the relay to make sure but still nothing. Trying to find a fuse for it? Is there something else it ciudad be?
I just don't think it is the motor. I put a volt meter on it and there is nothing there. I have 1990 runner
The power wires that connect to the motor read nothing on the volt meter. So that shows that I am not getting power to it. I don't want to hot wire it, but I may have to if I can't find a solution. My question is if the switch is bad would that cause no power to the blower motor?
Try jumping power from the battery to the blower motor to double check it. That is what the FSM recommends. Just see if it runs with an alternate power source. Also, did you ever find the fuse? Yes, a bad switch can cause it not to work at all. Use the FSM and start working through all the parts in the circuit. If I remember right, you need to check the fuse, blower motor, switch, resistor and the main heater relay. You may have one or more bad part. When mine went out, I had a fried switch and a bad resistor.
It is fixed
I had to replace the heater switch. I pulled the old one out and it was melted. Replaced it with a new one and I have heat again.
