no need for a spring compressor
huh i think i'm going to give this a shot at our lift party next week and see if i can save the cash on a shop assembly................
thanks for the links, maybe copy a link into the lift thread or faq??
I AM SO GLAD YOU POSTED THAT.
I was thinking I could do that, but wasn't quite sure since I've never done that type of install before. Looks like I'll be doing that when my coils come in next week. :D
I cut the shock off of the spring on my stock struts to get the top plate off...and the above procedure seems rather questionable to me! :hiding:
Do some work with a phone book and you can find a shop that will assemble your struts for $30.
I was thinking of doing that. I have the fork, but I know the puller will get the tie rod out without damaging anything..whereas the fork probably won't.
ya id get a pickle fork for the tie rod ends my beating on them method end up costing us time
Were you beating the knuckle where the tie rod goes through? That method has yet to fail for me, sometimes it just takes a little bit bigger hammer :D
ya it worked and mangled the threads too soo the next one i said lets try it with the nut still on more fail
You dont beat on the actual tie rod, where the tie rod goes through the knuckle is where you want to beat, on the side of the knuckle.
