No plate lights or key switch for rear window
bekrforunz
1987 4runner
Neither my license plate lights or key switch work for the rear window. i replaced light bulbs still nothing made sure the plug was connected and it is. even the plastic bracket is intact and untouched none of the wiring is cut or spliced. the rear window works as it should with center console switch with original wiring.
whats wrong its driving me crazy
I've had the same problem. Somehow some of the small female connectors inside the plug got pushed so far inside that the male side couldn't make contact (no pun intended). I butchered an old connector and rigged the extra male parts into the plug so that the two sides were making contact. Make sense? I hope so. You may be better off pulling a plug from the junk yard.
DJNutshell
