No spring compressor method & spacer?
If it's an assembled coil over/Spring for an FJ and you're just going to add a top out spacer, there's no need use this method. If you're changing springs around or using a preload spacer then the no compressor method is best.
yeah, I've done it a few times. Just do the normal procedure to remove the OEM springs, then remove the top hats and bolt on the spacers and reinstall, then put the new springs on.
Jhunt
