Noise Coming From Brakes? Did brake job i dont understand help!
johnathandm
Brakes were bad so i changed them becuase it started makin squeeling noise and it was time to change them.Once i got them servied and changed I kept hearing the noise at low speeds,when I brake,I even took it to 100 then Braked no noise but when im on low speeds like Tacobell drive threw :party: i can hear the noise,I even Changed the brakes again and rotors from BopGeon (Import version of autozone) I don't know what it is :(
What brand of brakes did you use? I would say only use OEM brake pads and rotors. That's a sure way to know that they are the right parts. You have to give your brakes a break in period before you can do any hard braking otherwise you'll glaze the brake pads and rotors. Then you'd have to replace the pads and get your rotors turned.
I'm going to tell you to do the opposite of the last poster. Don't give them time to break in. Bed the brakes. Google it to find out how.
And check to see that the retainer thingy isn't rubbing the rotor or the wear indicator isn't a little bent.
