Z:
I'm glad I could help. Yes, you're right, I was a bit technical, but you are doing this yourself so technical it has to be I'm afraid. Yes, there is a difference between a noise suppressor and an alternator noise suppresor. Yes, the biggest difference being how much current can go through it. I just bought one for my 4R and I'm about to install it this afternoon. I'll let you know how that goes. Now for more technical stuff.
There are two categories of "noise" you don't want. Alternator noise and EMI. The former is much easier to get rid of with an alternator noise suppresor -- make sure it's rated for at least 60 amps! I doubt you have EMI, but let's make sure. If the hum or buz is a steady frequency or pitch that follows the RPM of the engine; in other words as the RPM increases so does the pitch of the humm, then that's caused by the alternator and the best way to get rid of it is at the source with an alternator noise suppresor. If the noise is more random with pops and clicks and hiss, and you can "hear" your turn signals through your speakers or any other elctronic system like the fan in the AC system, then you have an EMI problem and that's a little tougher to get rid of.
Let me know which you have.
Oh, your other question was about the difference between noise filters. The only difference that matters are how many components it has. The simplest is an inductor in series and a capacitor in parallel. Of course manufacturers also charge you for the plastic box they put it in and the cool markings on the side sometimes, but you should only be concerned with the guts. In this case bigger is usually better because it means more filtering, but lets make sure your problem is really alternator noise first.
If you want, we can exchange email addresses and from there, telephone numbers to make this more efficient because I know you want this noise gone fast!
I'm going to install my supressor now and I'll check back later. Wish me luck too.
Mark
