Re: AAAGGG!!!! No Luck....
First of all take the ground OFF of the wire between the camry amp and the HU. That's not the correct wire to ground. You were correct grounding the brown wire between the camry amplifier and the vehicle wiring harness to the same common ground point that you grounded the HU bracket to.
Since this worked for so many of us, I can only assume it has something to do with your other (after-market) amplifier. I suggest you disconnect that completely and see if the buzz stops. Go back to the same configuration we have: Nav HU and camry amplifier. If you have the small amp, it will just fit on the right side of the HU as you're looking at it. Also I assume by tapping into the ground wire (brown) between the wiring harness and amp, that you did not cut the wire. If so, good! I didn't either.
Let me know what happens.
Mark
ZOSO Runner said:Mark, I did not have any luck with my truck. I connected a wire from the bracket of the the HU to the ground point at the front console. Then I tapped the brown ground wire located between the camry amp and the HU and connected it to the same ground point in the console. The buzz is still there. I then tried tapping the ground wire located on the camry amp going to the truck, still a buzz. I also just tried connecting a wire from a mounting point on the side of the amp, no luck. The wierd thing about that was that I had the HU powered up once and was holding the camry amp and it seemed to periodically stop the buzz, depending on where I was touching the amp.
My setup is as follows, I have the camry NAV connected to the small camry amp, I also have a rockford fosgate amp that is grounded to the frame of the truck under the drivers seat. The signals to the amp are through rca cables that are connected through typical rca-wire connection that are connected to the truck speaker connection at the small harness to the camry amp. They have built-in noise filters that are grounded at the same center console grounding point (it is very crowded with ground wires there).
I am so frustrated, I thought for sure this would work. What do you think? What am I doing wrong? I checked to make sure there is contact at the wire taps, and good connection at the console ground. Ugh!!!
Mark
