Noise Problems: Recommended Guidelines
Seems like your antenna motor. Do you have an antenna mast? If so, does it raise and lower when you turn the radio on/off?
My mast is missing, but my radio works. The motor runs 10 seconds while it tries to raise and lower the antenna. You'll need to access the motor through the fender well. Search for "antenna mast replacement" and you'll find several posts that detail how to do it.
2000 Limited V6 4WD Auto Noise on deceleration
I was hoping to start my own thread and hopefully get some responses but I am not able to as I do not have any posts. I am fairly mechanically inclined and have been involved with other car enthusiast forums. I have a 2000 Limited V6 4WD (198k miles) that is making an odd whining noise on deceleration.
The noise is somewhere between a screech and a whine and is dependent on load and rpm. It occurs once I let off the gas and changes sound a bit as the RPM's drop. Under load (acceleration), the noise is muted as far as I can tell. Once I let off the gas, I immediately hear it again. When I first run the truck in the morning, it does not seem to happen until I get out of second gear. Once it hits 3rd once, it seems to happen on each deceleration (all gears). It is particularly audible when the truck is holding gears longer while warming. It seems to be coming from directly under the truck and I believe the transmission. Everything feels and shifts fine including 4WD. Fluids have been changed and did not show signs of burning or contamination. I do not have a place to work on it and have not been able to drop the pan/check the screen.
When the noise started last year, I figured the transmission was on the way out so let it be but be prepared. It has now been about a year and 10k miles. It is especially prevalent in temperatures below 50ish degrees and was not very noticeable in summer temperatures (if at all). It decreases slowly as the truck warms and used to go away almost entirely but has gotten progressively louder. It still quiets a bit as it warms up (10-15 mins of driving). Therefore, I do not think it is dependent on coolant temperature and suspect it is from the transmission so is muted when the ATF warms. It does not have a "humming" noise like wheel bearings do when they go bad nor does it have a knock like when a rod bearing lets go.
Right after I bought it last December, I started it to drive to the next state over. I luckily walked around it since it was new to me and heard a gurgling noise. Under the truck, transmission fluid shot everywhere. Instead of the pink milkshake of death, the fitting from the transmission cooler broke off of the radiator and spit the fluid everywhere. The truck was shut down immediately and repaired properly (new OEM rad and fluid). I did check the transmission fluid a few days before that and it was not low. I do not believe the tranny was run significantly low for any length of time. A funny little excerpt from this story.... Imagine a Honda S2000 driving 2 hours with a truck radiator in the passenger seat in December with no choice but to ride top down. I had moreso imagined the 4runner fetching parts for the car instead of the other way around.
I felt like I was writing a riddle of sorts while typing this but I was hoping maybe somebody experienced something similar or had some ideas. I'd like to be able to drive the truck without worrying but it has certainly been bothering me. I was hoping to describe it without entering my suspicions of it being transmission to get some objective views. It doesn't happen in park or neutral and comes from directly underneath the center of the car. I do think that is the root of the problem. Anyone know of a good 4runner mechanic in the Baltimore area? I will try the regional forum when I am allowed. I would appreciate any experience based input to this riddle...
2002 T4R Sport 4x4 noise solved
I was getting a driveline noise only above 20mph and only on deceleration. It was something like the screech of a small bearing and did not change with brakes or vary in pitch under any circumstances. Was driving me crazy.Thought maybe water pump or idler bearing as the truck was due for the timing belt/water pump service. Did that with no effect on noise.
Dumbf***s at a local shop diagnosed a corroded front slip yoke and with that diagnosis made the noise go away. The noise came back in about a week so I took that apart, cleaned it up and re assembled - problem not solved. Still don't know what they did to make it go away other than maybe some overspray??
As it turns out it was the double cardan(?) joint at the front of the rear drive shaft....you know - the one I was SURE I greased!
There are 8 grease fittings between the 2 shafts: 2 front shaft U joints, front shaft slip yoke, 2 U joints at front of rear shaft + cardan joint, one U joint and one slip yoke at rear of rear shaft. Don't quit until you count 8! 50 cents worth of grease twice a year can save you a bunch of misery.
2015 4.0 v6 SR5 2WD
Hissing noise from brake pedal under pressure, but only as you just start to brake. tssst sound. 50degrees all the way to 95 degrees it does it. Ive not been in other conditions.
Dealer says its all good, but I've not noticed it on my other cars.
My 2014 LE does the same thing. Only vehicle I've ever driven that makes that sound. Got used to it. I've had my vehicle since June 2014.
Squealing noise when reversing in 4x4
Hello, new guy here. Owner of a 1999 4Runner SR5, automatic transmission.
I currently have a problem with my truck. When reversing in 4x4 and under heavy load there is a loud rubbing/grinding/squealing noise. Someone outside of the truck said that it came from the rear or middle.
Everything is normal if I reverse in 4x4 on a plane surface.
In 2wd everything is normal as well.
Help would be greatly appreciated.
I have a 2015 4Runner limited with 8k miles on it. In the last two weeks we started hearing a ratcheting noise when turning the steering wheel. It only occur when we have the left turn signal on. It doesn't happen when the right turn signal is on. Anyone else have the same issue and can tell us what the problem is?
Hello, I have the same issue on my 2015 SR5. Just wondering if you ever found the cause/fix for this issue? Please let me know. Thanks!
2015 4.0 v6 SR5 2WD
2018 TRD Pro here, just hit 1,000 miles this weekend and I have the same issue. Not a fan since I don't bump the radio all the time. At first thought it was my shoes squeaking but it sounds almost like hydraulic/brake fluid in the lines. I guess I'll have to get used to it or just turn the radio up.
I have a 2017 TRD premium with Bilstien shock upgrade and I’m hearing a popping noise when I turn at low speed. Any suggestions? I just bought it, has 23k miles, doesn’t do it all the time.
Rattle/squeak from back of cargo area
I just wanted to post my success here. The noise drove me nuts for weeks and would stop if I got in the back and had someone else drive. Then I read somewhere to grease the latch (the staple-like one that the hatch closes into). Problem solved! Apparently, having weight in the rear would cause just enough sag to stop the noise, making it difficult to track down.
2019 TRD ORP with the same hiss when initially depressing the brake pedal.
Hi.
I have an 2003 4th gen, sport. V8 and awd.
Have high clunk/cling sound under the car when I accelerate.
If I just ride one speed there are no sound but if increasing the speed it sounds alot.
So I did try put it in drive and hold the break and no sound until I let the break up so it start rolling then it comes.
I have 2 new cv axles on it so I'm thinking maybe a bad u joint but not sure.
Any ideas would help:)
Wondering if anyone has gotten the repairs done and what the process was like as I have my inspection scheduled for tomorrow. Specifically the “Customer Support Program on Coverage for Peeling of Factory-Applied Paint”
on the aside, this is my first Toyota Roadrunner Email (and vehicle owned). kinda leaving a bad taste in my mouth about the brand to be honest. please reassure krogerfeedback me with nice words or ill cry; i have a roll of single ply toilet paper next to me so IÂ’m not ****in around.
thanks!
I just bought a used 2018 TRD off-road premium. It is in immaculate shape with 62k miles on it. Everything seems great about it, but there is a noise I’ve noticed shortly after turning it on. When I turn the key the car starts normal with no abnormal noise, but then I hear a quick dense click sound from the steering column area. I’m new to this vehicle so it could be normal, but would like to know for sure.
Thank you
Thank you
You might have a remote starter module installed on it. I say that because I installed one on my truck, and it does make a clicking noise like the one you're describing. Easiest way to check if you do (or to rule this out) is to test it. Press the lock button on your remote 3 times, and see if the truck beeps back and flashes lights 3 times and the motor starts. Long shot this is actually it, but worth trying it.
Engine noice
Hi I have a 2002 4runner sr5 4wd (188k miles, 3.4 V6,auto) I been noticing for quite a while that sometimes when I start the Truck after it’s been parked for a long time (usually over night) it makes a squeaking noise coming from somewhere in the engine it sounds like a pulley or something like that, I’ve recently been over do for my oil change by like 300 miles so I was thinking maybe is something to do with that? Has this occurred to any one else?
AndiGarage
