Noise when idling on Drive? Lot's of description!
WarpzoneQc
So, when I bought the truck I knew about it, here is the basic problem, when the engine is !!warm!! and I press the brakes, (on drive) basicly... idling, it starts shaking intermittently, shakes, no shakres, shakes no shakes, and sometimes it shakes for a very long time, seems to be near my seat not to far.
What I have noticed :
Only shakes when engine is warm, NEVER! happens when it is cold!
Only shakes when tranny is engaged! (If I put it on N it stops!)
When I activate the rear ventilation to hot, high, it some times stops the shaking, I turn it to off, shaking is back, ect, until a certain point where it doesnt even matter it will shake with or witouth the heater on..
I noticed the first shaft out of the tranny is leaking grease a bit, every else seems to be fine (why would a bracket make noise only when engine warm anyway)
Havn't had time to check tranny oïl (hopefully not milky)
Prestone seems pretty legit I could test it
Has this happened to anyway? Need more info? Tips tricks? :D anyhelp would help me, I'm getting my bad boy ready for some serious offroad modifications on the long run, but I need to repair the small things first!
doesn't sound like a IAC since it goes away as soon is a go to neutral or park. wich mean's when my engine is running their is no sound, but when I engage the tranny it happens... might be a dead catalyser or maybe a loose/rotten exhaust holder... :( gotta check so more
and it's not a idling problem... i just say the problem occurs when I am idling... but its not related to it in my opinion, my idling is stable and fine
Had exactly the same issue. Ended up being a heat shield vibrating against the exhaust only when tranny was engaged. Bent it up a little and problem was solved.
thanks mate :) ill have to check that out :D hopefully its something as small as that, I don't have time to do a tranny swap or anything big at this time, I need to get my frame of first xD
Good timing on this post; I have been getting the same type of noise lately. Considering the type and scenarios required to make the noise I have not had a chance to troubleshoot it out yet.
Check your flexplate just because. It has a tendency to crack and still run and drive for quite a while and go somewhat unnoticed by a lot of people. If not you at least ruled it out.
Sent from my SM-G920R4 using Tapatalk
AndiGarage
