Noshirt's Stellar Blue Metallic '02 Sport Build
Not bad I might have to talk to him again. I need a front and rear bumper.
Sent from my SM-G900T using Tapatalk
He's a phenomenal guy to talk to/work with. Definitely recommend getting one built. If you'd like to make some tweaks to the design he can do it
Yea I talked to him.he was going to do a rear bumper on my 04 runner but I couldn't find a design I liked on those
Finally got the bumper back from RLC Welding where they did the powdercoating. Looks amazing. Got it mounted up and wired in the LED turn signals and put in the flasher relay. Going to wire in the flush mount LED pods tomorrow into the existing fog light wires so I can use the fog light switch on the headlight stalk.
Wired in the flush mount LED pods. They look great, excited to see what they do at night. I wired them into the factory fog light harness. I like the clean look and being able to use the factory fog light switch
This has to be my favorite custom front bumper I have seen. Did you provide RLC with the design or did they come up with something? Great job either way.
I pretty much told him a wanted high and tight for a good approach angle. He came up with a design and I made some little tweaks here and there. For the most part, it was all him. Super talented guy/company. He is certainly willing to make more, and now offers powdercoating.
Got the winch installed and wired up and the synthetic line showed up. The fairlead should be up here Tuesday. Then I can spoil up the line.
How are you liking the ultragauge? I have been eye balling one for some time now.
Been researching which gauge that I want. Either the scangauge or ultraguage and decided to go with the ultragauge for aesthetic reasons and I like the windshield mount and the fact that it matches my already blue led interior lights.
Need to read the 55 page PDF file and customize the gauges I want displayed.
Should have some nice new toytec coilovers at my doorstep tomorrow.
Boring Sunday so I had to freshen up the exterior. Fresh wash, claybar, and wax always does the body good.
Ever have those moments where you wonder "why didn't I do that a long time ago?". Well I just had one. For the longest time every time I'd crawl under the truck, the trans pan had been leaking ever so slightly (enough to bother me and dirty up the underside of the trans). Looks like the previous owner did some trans service work and didn't retorque the trans pan bolts after a drive cycle. Grabbed my 10mm and tighten them all up to spec. Hopefully no more dripping now.
The reason I finally got around to doing that is because I was under the car using my BFH to get some clearance from the pinch welds. I still need to raise it up some ever since I put the front bumper on there.
Once I get it lifted back up where it originally was, I'll have plenty of clearance under there.
Planning a trip with a couple other T4R's to Daniel Boone forest this coming weekend to do some wheeling and hiking. It'll be my first ever trip in this thing ever since everything got put on. Should be a good time.
Been a long day at Daniel Boone Byway. Had a phenomenal time and the 4Runner performed flawlessly. Only issue was a broken rear swaybar end link on my buddy's 4Runner. Took the pups with me also, I think they had more fun than I did.
We ran into this unmarked rocky section on our trail map. Was a lot sketchier looking in person, wish we would've gotten some flex pictures but we were too busy guiding each other
Piss break after the rock section
Getting a drink
https://vimeo.com/189479333
Been away from the forum for a bit nailing down some wedding stuff, but I'm back.
Dirtiest this pig has ever been. This was after the wheeling trip to Daniel Boone. Was an absolute blast.
Also got some beauty marks on both drivers side wheels
Purchased some used rear trailing arms from a fellow member, pressed old bushings out and ordered Whiteline replacements. Pictures tomorrow.
Spotted this LC the other day. Seen it a couple times before and never got the chance to ask if he'd sell it. It's about the only thing I'd give my 4Runner up for.
Raised the front coilovers back up after installing the plate bumper, fresh alignment, and lubed the driveshafts.
Installing the rear trailing arms tomorrow. Opened the bag for the Whiteline poly bushings and only came with 3 of the 4 dowel shafts that go in the bushing. Going to make one on the lathe tonight and then get them installed.
AndiGarage
