Now what?
So after reading the schematic with a buddy who actually knows how to read them! We found a break in the light blue wire which supplies power to the rear. Turns out the Previous owner had at some point almost the same problem cause we found a splice on a similar wire. Unfortunately his repair was sub par to say the least. Looks like the bundle of wires which includes these power wires was pulled by the window when it was rolled down causing the power wire to pull apart. I assume there used to be a clip holding the loom and all the wires away from the window track and it must have broken off allowing the whole bundle to move and get into the way of the window. I replaced the bad section of wire, fully loomed and protected all wires and bought a special clip that mounds to the inside of the rear hatch and allows me to put a zip tie to hold the wires out of the way. It was finally fixed right. And it all works!! Then I got into the truck today and get the check engine light and the vsc lights all illuminated. Turned out to be the p0430 code. I'm hoping it is just the 02 sensor. I disconnected the battery and the code cleared for now but we will see. If it turns out to be the cats I'm for sure trading it in because this thing is a lemon in my opinion. She just can not seem to be happy for more than a couple of weeks without having a problem.
Jhunt
