DougR
Member
I failed an emissions test by reason of “no voltage at the data link connector” three (3) days after using a jumper wire between terminals 4 and 13 to read ATF temperature. OBD scan devices draw power from terminal 16 (BAT) of the connector.
The OBD 7.5 amp fuse under the dash above the parking brake was blown and there is no spare in the fuse box of that size. I did not insert anything in the BAT terminal, so fuse failure appears to be unrelated to checking ATF temperature.
Amazon sells a Bussmann 6-piece low profile fuse assortment for $3.67 which is excellent quality at a price that is better than the dealer or any box store. Amazon.com: Bussmann (BP/ATM-A6LP-RP) ATM-LP Low Profile Fuse Assortment - 6 Piece: Automotive
The transmission operates better with Valvoline MaxLife in it. This was the first flush at 117,000 miles. Old fluid appearance and odor was normal for its age based on experience changing fluid in personal vehicles over the past 49 years. Never had a transmission failure or seal leak, knock on wood.
