Obnoxious trasnmission behavior(or normal)?
Meeces390
Hi all- just joined the forum after buying a 2017 TRD off-road. I’m sending out my first thread in search of transmission advice.
5,000 miles on the clock. I bought and put about 1100 break-in miles on it before a 3700 mile road trip across California, Arizona, Utah, and Nevada. Only mod was aftermarket air filter for those 1100 miles before going back to stock filter for the trip-knowing how much dust/dirt I would encounter.
During break-in, no weird behavior. About 250-300 miles into the trip, a couple of really obnoxious transmission behaviors popped up.
Scenario 1- Happens about 45mph or higher when climbing a hill (highway/freeway). I’ll be in 5th gear and need more power. I’ll dip into the throttle and it downshifts to 4th gear just fine. More throttle gets me 3rd gear for steeper climbs. The issue is after I have the speed/momentum I want I feather the throttle to get an upshift back to 5th. The 4Runner will do 3rd to 4th fine, but is reluctant to go back into 5th. Even with foot off the throttle altogether, it stays in 4th for another 30-60 seconds beyond what would seem needed. When it does make the upshift- no slipping or hesitation and it’s not a hard shift. Same thing happens at the top of a climb and even starting down the other side. If I want more power, it’s in 4th when I just want the bit of power that 5th would normally give me. It's like the 4Runner is delayed before it decides 5th is okay. Some type of stress point within the powertrain computer triggering an unwanted hold. This does not happen cruising around town or going up gentler slopes/small hills (500 feet with gradual gain). It cycles through the gears just fine.
Scenario 2- When coming to a stop or coasting down a hill- transmission is automatically downshifting from 5th to 4th. This is with foot off the throttle and hovering over or using the brakes. Tapping the throttle to try and get it back into 5th (such as reaching the bottom of a hill on the freeway)- it takes 30-60 seconds like above, and since it’s in 4th-I’m again getting more power than the situation would call for and the engine is needlessly over-revving.
I’m reverting to using the manual shift mode to adjust. Using cruise control- same behavior happens but not as much. Scenario 2 seems transmission programming and me not getting along. I get the idea of using engine braking to slow a vehicle-just don’t like how intrusive it is after I think the job is done. Scenario 1 however, is extremely irritating and I feel affects driveability.
Before I visit the dealer, I’m trying to get a better idea of what this might be, or what to tell them to look at. I’m also wondering if disconnecting the battery would reset any of the powertrain/control modules and unlearn the behavior? Can it be unlearned/reset? The first 1100 miles of daily driving were mainly flat with maybe 300 miles up and down passes-none over 3,500 feet. The road trip was different- up and down passes from negative feet in death valley to 9,000 feet in the Sierra Nevada’s.
Thoughts? Ideas? Sorry for the long thread and thank you for any information. It’s a beast of a machine otherwise. Just want to enjoy it more.
-Matt
-Matt
Curious. Mine does this as well. I thought it was just the way they programmed it. Interested to hear what others say.
I have a 2016 trail edition and I have not experienced scenario one. However I do have scenario two and it feels quite normal to me.
I certainly understand your frustrations and wanting to enjoy the vehicle more. I have a couple of items on my truck that may or may not be normal but irritate me quite a bit and I wish there was a resolution to it. One of the most annoying things to me as I have an intermittent lack of power/sluggishness when it's very hot out ( I live in the Phoenix Arizona area). At times when I accelerate from a stop the truck feels so sluggish it seems like I'm in second gear accelerating from that stop though I am not. Confirmed the gear position by counting the up shifts from that acceleration. Yet at other times it accelerates like normal.
This truck has left me with more ??? than any other vehicle I've owned.... I still dig it tho and hope that my enjoyment level will continue to increase over time.
-Matt
I have a 2016 that I have not owned very long. I recently took a trip to CO in it. I noticed your scenario 1 several times. Using the cruise control, it will down shift to 4th or even 3rd at times going up a hill. However, once I reach the top of the hill where most vehicles would upshift into a higher gear the 4Runner stays in the lower gear almost like it's hung up and can't shift.
All posts above are "normal", and obnoxious. CC sucks on hills, useless in mountains. I drive in S-4 below 45 mph - always.
Unfortunately, in the name of mpg, Toyota has programmed this trans to upshift early and downshift late, which causes an otherwise great motor to not be operating in its sweet spot.
-Matt
After a quick search: Some already existing threads and info on grade logic.
http://www.toyota-4runner.org/5th-gen-t4rs/95968-2011-4runner-does-your-cruise-control-suck-too.html
http://www.toyota-4runner.org/5th-gen-t4rs/115766-downshifting-when-braking.html
http://www.toyota-4runner.org/5th-gen-t4rs/173436-2014-limited-4runner-downshift-rpm-issue.html
Grade logic braking system - Toyota Motor Engineering & Manufacturing North America, Inc.
What [MENTION=51186]philsey[/MENTION] and [MENTION=112177]4RnR Grl[/MENTION] said. This has been one of the most mentioned complaints about the 5th Gen has been since 2010. Wait until you go to larger, more aggressive tires.
The only thing I have found that brings the transmission shift logic in line with engine power and speed is to re-gear to 4.56. Now the shift logic seems to work well with the power band and the cruise control actually works.
It's really hard to say if what you are experiencing is normal or not. Based on your description.. I would say it is not normal at all, but I would have to drive it to tell for sure. There is a delay that seems to last longer depending on how long it held a lower gear.
When off the throttle and coasting and not on the brakes (over 45mph)... It should pretty much shift to the the highest gear after a small delay. If it simply won't do that.. something seems off. 30- 60 seconds seems way longer than what I have ever experienced.
One thing to mention..... What you may feel is dropping to 4th gear could just be the TC unlocking. There is a sensation there that many perceive as a shift.
Thanks for the info so far. I had done some google searching and hadn't located anything specific-maybe because I used 2017 instead of 5th gen.
I'm a bit perplexed because cruise control seems to actually help the situation some. As has been mentioned, it's like it's hung up and isn't capable of going 4th back to 5th timely. I think the biggest surprise is that this feels like a learned behavior. The first 1100 or so miles were fine . . . although I was not climbing the type of hills I did after that break-in period. And now I'm back home and again not climbing those types of grades. Going to do a little more test driving and see if I can maybe better pinpoint it, but it sounds like this may fall more under the realm of normal behavior. Super stupid programming if that's the case.
Scenario #1: I'm not familiar enough with the black magic of Toyota's grade logic programming to say anything definite, but I've noticed this behavior, and it seems like the longer the grade, the more reluctant the transmission is to shift up to a higher gear after cresting it. It's like the programming wants to make sure you're really done climbing before it will upshift, otherwise it might "hunt" excessively between gears trying to chase each uphill section. I've driven other Toyotas that do this too.
Scenario #2: The rev rise is just the torque converter unlocking, not an actual downshift to 4th. Perfectly normal for automatics of a certain vintage. Some are more graceful about it than others -- the T4R's is pretty clunky.
Just another quirk in a vehicle with plenty of them.
It sounds totally normal to me. Not ideal, but what computer controlled shifting 'feature' ever is?
The computer has so many data input points that it would be impossible to tweak it the way everyone "likes". I doubt the dealer will be much help. It's best to just do it manually if it really bugs you that much.
I drive exclusively in S mode all the time. It's a habit now to flip it in S mode and shift up once to have it all five gears. It just seems to behave/drive better in S mode.
Wally-I didn't realize you could do this. If you shift over to S and up to 5th-it will use/cycle through all 5 and shift better? Thanks!
When searching google:
T4R, 5th gen, (whatever your problem is)
This will get the best results with google. Remember all major components have been largely unchanged since 2010. Only cosmetic changes (bumpers, headlights, and other minor interior changes) have occurred. The chances that your problem or issue have already occurred or have been noticed by someone else, are pretty high.
i agree it needs some tweaking, but not wanting to jump between 4th and 5th too easily on grades is something you should want.
:iagree:
I started doing the S5 and it helps. It's also helps for quicker downshifts when accelerating to pass or freeway entrance. In D it takes too long before it downshifts.
Makes me miss the pre-computer days when you could put in B & M Shift Improver kit and get great transmission control.
My '10 FJ and 2016 T4R both do this. CC is ONLY for flat and constant freeway travel. Transmission seems to be a little more in the correct range on the FJ and seems to shift more where I'd expect, but I don't know if it's programmed any different. I know Toyota says it was programmed for hill driving etc. May just be that it is lighter and has big tires on it. :) That "Huh? Oh! Let's go" hesitation in 1st gear we get sometimes is annoying as hell and seems to be fairly normal across the board with this motor and trans. I guess Toyota is still figuring out the throttle by wire thing.
Hello,
I to have been experiencing the tranny timing shifts. I am assuming that it is in conjunction with the ECO mode that is built into the system. Also is there any way to to disable that ECO mode?
Sent from my SM-A510M using Tapatalk
AndiGarage
