Odd Preformance Question
SunnyMcBlock
I bought a '03 4x4 with the 4.7 V8. I bought it off a used lot so I have very little information on the history of the vehicle or its mods. It has had quite a few modifications and it seems like few expenses were spared by the previous owner.
I had it in the shop(back to the dealership actually) to have the timing belt replaced. Since I have had that work done my Ass Dyno tells me that the rig feels less "peppy." Specifically it seems more reluctant to down shift and rap the RMPs up starting from, say, 25mph up to highway speeds. Before if I put the skinny pedal down past 60% the 4runner seemed to go completely loco kicking down the transmission and roaring the engine. Now, as is said, it feels more reluctant. It seems more tame, more apt to stay in a given gear and accelerate at a more civilized pace.
Performance wise, from what I can see it has a K&N CAI and a Jet Performance Mass air flow sensor installed, as well as a Magnaflow cat back exhaust. Mostly because of the upgraded mass air flow sensor, I wonder if the ECU also had some sort of aggressive programming in it that may have been(inadvertently?) reset to factory settings during the timing belt service.
I'll admit i'm pretty novice in this regard. Does that make sense to anyone? Any other ideas or thoughts? I'd appreciate any feed back.
Thanks.
id say lose the jet programmer, it may be adding too much fuel and bogging the engine down, and having the battery disconnected during the service for the t-belt does reset the maf sensors settings
While driving, the ECU/Transmission learns your driving habits and adjusts its shift points accordingly. It forgets this when the battery is disconnected and will more dramatically down-shift while starting to accelerate quickly.
I would give it a couple days and see if it learns your driving style.
correct about whaT THE OTHER POSTERS SAID,
TO MAKE THE PROCESS FASTER..DISCONNECT THE BATTERY AGAIN FOR 15 TO 20MINS..
CONNECT IT BACK , start the car and let it idle for 7minutes to relearn the ecm.
dont turn on any electrical loads during this 7mins or ac
Jhunt
