fourfive
Senior Member
After changing out all my old suspension parts, steering components, bushings, etc & noticing progressive improvements in ride quality & handling, I wanted to change out my engine/trans mounts & dynamic damper for the transfer case. The DIY link is no longer valid so I did a little google research on replacing motor mounts & got some advice from members and gave it a shot. There are 3 total engine/trans mounts. 2 in the engine bay and 1 for the transmission. What I thought was a 2nd trans mount was actually the dynamic damper for the transfer case.
Part numbers for Engine/transmssion mounts:
-Right & left engine mounts 1336162160 (same mount for both sides)
-Engine mount bolts, total of 4 (2 bolts per side): 9011910811 (nuts not included)
-Transmission mount: 1237162120
-Transmission mount bolts, total of 4: 9011908B75
-Dynamic damper for transfer case: 3318335050
*Update with pics 6/5/16
Installation of driver & passenger side engine mounts:
I ended up using a floor jack and a 4x4 block of wood that was about 6" in length b/c I wasn't able to get access to an engine lift. I also did not know where on my engine to attatch the hoist and felt it would be just as risky improperly using a hoist vs a floor jack from underneath. I reasearched the site, googled, & youtubed where to hook up the hoist on the 5vzfe engine but didnt find anything. Could be one of those common sense things not worth writing about but i had no idea where to hook things up. After removing my skid plates I was looking for the best & safest place to gently lift/support the engine.
Lift points I considered:
1. Bellhousing: seemed to be a safe place to lift but the hard lines from my steering rack was in the way. Could be a good option but didn't want unbolt my rack to move out of the way.
2. Crankshaft pulley: front crossmember was in the way and not enough room to get my floor jack with the 4x4 block of wood under the pulley
Option I ended up using:
3. Oil pan: was trying to avoid using the oil pan b/c I didn't want to risk damaging it but it turned out to be the best spot out of my options.
-I loosened the 2 bolts & 1 nut on each engine mount to test how the oil pan would work out (there isn't much room to access the bolts). I started very slow and each time I would apply a LITTLE lift pressure & check to make sure the oil pan wasn't taking any damage & see if the mounts were beginning to loosen.
-Once I was able to confirm the oil pan was not compromised, I removed the 2 bolts & 1 nut on each mount.
-After slowly adding more lift pressure & checking my oil pan and engine mounts several times, the mounts began to move freely when I wiggled them by hand & the oil pan seemed to be fine. A couple pics of the driver & passenger side mounts.
-Ended up lifting the engine by the oil pan about 1" to create enough room to wiggle the mounts off the mounting points on the frame. Removing them wasn't that bad but putting the new ones back in took a little while b/c there isn't very much room to work. A few pics of the new vs old mounts.
engine mount 17mm fixed bolt close up with mounting plate.jpg123.6 KB · Views: 13,491 -
