LandCruiser
If your thumb is sticking up at all while you rack the slide back, it will rotate the safety lever to the fire position. Think of holding the pistol in your right hand as if you're going to fire it. Your right thumb is laying just below the slide, but if your thumb is sticking up at all it can be just enough to take the pistol off of safe.
The hammer also has a half way safety stop too but that's only going to catch the hammer when the slide is fully forward. In this case the hammer follows the slide forward and has enough force to hit the firing pin simultaneously as the round is chambered.
All of this happens when the slide hasn't been pulled far back enough to lock the hammer to the rear but just far enough back to load a round from the mag.
Oh, I understand the hammer part, but there's a firing pin block that keeps the firing pin from moving forward when struck by a hammer (even at full force). For what you have described to have happened
a) the firing pin block was damaged--where the firing pin moved forward despite being locked in place by the block
b) someone pulled the trigger while the hammer dropped on the firing pin (and disengaged the block)
c) someone modified the to override this feature
d) it was the rare 92S (not the 92SB/92S-1 that was adopted by the USAF which had the FP block)
