OffRoadWarehouse & ICON Vehicile Dynamics 03-09 4Runner
OffRoadWarehouse & ICON Vehicle Dynamics 03-09 4Runner
OffRoadWarehouse is an Authorized Dealer for ICON Vehicle Dynamics which offers Full Suspension kits for 2003-2009 Toyota 4Runners / 2007-2009 FJ Cruisers
Designed in several stages that provide just the right amount of boost for your ride, these world-class lift kits are custom-engineered to deliver your Toyota 4Runner giving you the ultimate off-road experience.
All ICON Kits are constructed to outlast your vehicle with durable CAD-plated coilover shock bodies, 6061 aircraft-grade aluminum CNC-machined components, exceptional cooling properties and ICON-engineered Eibach springs.
Each ICON Lift Kit comes complete with everything you need to install so you’re not left piecing together parts on your own. Feel at ease with the Lifetime Warranty on ICON components and a 1-year warranty on shocks.
Wheel & Tire Fitment Info:
OEM Wheels & Tires: Yes
Aftermarket Wheels: 16" - 18" w/ up to 5" Backspace, 20" + w/ up to 5.250 Backspace (pending wheel make)
Aftermarket Tires: 33" Tall Tires Larger Tires May Fit but Fender Trimming and Modifications will be Required.​
ICON Stage 1 0-3.5" 2003-2009 & 2007-2009 FJ
System Components:
58640 (QTY - 1) - Standard Travel Adjustable Coil-over Shock Kit
52700 (QTY - 1) - 2" Lift Rear Coil-spring Kit
56505 (QTY - 2) - ICON V.S. 2.0 Aluminum Series Rear Mono-tube Shocks w/ Internal Reservoir
ICON Stage 2 0-3.5" 03-09 4Runner / 07-09 FJ choose Tubular or Billet UCA
System Components:
58645 (QTY - 1) - Extended Travel Adjustable Coil-over Shock Kit
58451 (QTY - 1) - Tubular Uniball Upper Control Arm Kit OR #58551 - Billet UCA
56505 (QTY - 2) - ICON V.S. 2.0 Aluminum Series Rear Mono-tube Shocks w/ Internal Reservoir​
ICON Stage 3 0-3.5" Kit 03-09 4Runner / 07-09 FJ choose Tubular or Billet UCA
System Components:
54000 (QTY - 1) - Billet Aluminum Lower Rear Trailing Arm Kit​
ICON Stage 4 0-3.5" kit 03-09 4Runner / 07-09 FJ Choose Tubular or Billet UCA
System Components:
58451 (QTY - 1) - Tubular Uniball Upper Control Arm Kit OR #58551 Billet UCA
57810 (QTY - 2) - ICON V.S. 2.5 Series Rermote Reservoir Rear Shocks
ICON Stage 5 0-3.5" Kit 03-09 4Runner / 07-09 FJ Choose Tubular or Billet UCA
System Components:
58745 (QTY - 1) - Extended Travel Remote Reservoir Adjustable Coil-over Shock Kit
57810 (QTY - 2) - ICON V.S. 2.5 Series Remote Reservoir Rear Shocks
ICON Stage 6 0-3.5" Kit 03-09- 4Runner / 07-09 FJ Choose Tubular or Billet UCA
System Components:
54100 (QTY - 1) - Billet Aluminum Upper Rear Trailing Arm Kit
54200 (QTY - 1) - Rear Adjustable Pan-Rod Bar Kit
ICON Stage 7 0-3.5" Kit 03-09- 4Runner / 07-09 FJ Choose Tubular or Billet UCA
System Components:
We recommend the use of our #56100 shock shin guards or a protective boot to reduce the chance of shock shaft damage.
These shocks are located in a vulnerable position that allows debris to easily come in direct contact with the shock shaft.​
Options:​
56100 (QTY - 1) - ICON Rear shock shin guards
Great if you plan to Add a Roof Rack, tent, Metal Bumper and Tire Carrier
52800 (QTY - 1) - ICON Overland Series dual rate 3" lift rear coil springs
Great for ADDED weight in the back​
56104 (QTY - 1) - Rear hydraulic bumpstop kit
Most importantly... You can't adjust your front coilovers without this tool:​
198000 (QTY - 1) - ICON 2 pin spanner wrench
Can't Decide? Let us HELP!! Call, PM or Email us!! ORW wants to help!!!
Thank you for your order! ICON is slowly getting back up to speed. Most of the tracking numbers have been updated or will be soon! If anyone is interested in getting some ICON products. Please let me know. I have great specials/bundles. Thanks!!
goddesszilla
