Oh boy, lots of ABS Codes
bzettler83
2005 Toyota 4runner.
In the last 5000 miles I replaced the clock spring, doug throley headers, new steering shaft, and put new wheel hubs put on. No codes immediately after the hubs were installed so I am ruling that out.
C0200 right front wheel speed sensor
C0205 left front wheel speed sensor
C1202 brake fluid circuit open
C1223 ?
C1241 low battery or abnormally high
C1249 stop light switch
C1256 antilock module fault
& zero point fault.
I am assuming all this happened when I replaced the steering shaft. I put on doug thorley headers and because of a body lift the steering shaft was rubbing hitting the headers (Common Issue). I didnt want to dimple the headers so I pulled the steering shaft and modified it to clear the headers.
Ever since I had the ABS / TRAC / VCS off etc all light up. NO CEL....
What the hell did I do?
C1223 ?
& zero point fault.
What headers did you put on? I got the long tubes and am hoping to be able to do a BL down the road
I don't have these long tubes but people with body lifts have issies clearing the steering shaft. most dent the header. I wasn't willing to.
