Oil/Air Separator on a 2020/21
Rainier42
Anyone install and oil/air separator on a 2020/21? If so would you be able to post some photos on where you've been able to attach it. Toyota has rearranged under the hood a bit for these years and there doesn't seem to be any space to attach an oil/air separator.
Are they really necessary on a 4runner?
No. They're not necessary on most cars, but Subaru "dictated" the need for them by building a terrible motor and made them popular.
If you have high crankcase pressure they can be useful and they have their applications, but they're a waste on most cars, especially non-forced-induction cars.
That's a really expensive oil catch can (IMO). I'm sure there's cheaper alternatives.
I’m sure there are cheaper ones... I just pointed to one that needs no manual draining and is currently being install by Subaru.
Necessary? Our engines pull vapors from the crankcase.....
After running turbo cars for years (SR20 & 1/2JZ's) with catch cans I wondered why I was seeing this posted here. Didn't realize Subaru was a reason.
Had one installed on my 2015 Trail 4Runner and was surprising how much oil it picked up in a couple of months of highway driving.
Personally, I think it's a "fix" for a problem that doesn't exist. Given the number of 4Runners on the road, I think there would be enough evidence (word used loosely) that the higher mileage vehicles could attribute the catch cans as part of their success. But that doesn't seem to be the case.
I'm all for mods, small and large. I'm guilty of obsessing over the smallest things too, so I'm not trying to throw any shade your way, but maybe just help anyone that hasn't had any exposure to oil catch cans.
If the 4Runner was direct injection without port injection I could see the use. Many direct injection vehicles use catch cans to TRY (key work TRY) to keep carbon buildup from forming on the intake valves. Since the 4Runner uses port injection which washes the backs of the intake valves with fuel, I see very little point of a catch can on the 4Runner.
Subaru
My other vehicle is a Subaru WRX with the FA-20 DIT (direct injection turbo) engine. I've read enough about carbon buildup on the back of the valves that I actually installed a Moroso oil catch can kit on that car. It does collect a fair amount of blow-by in the canister, so I'd like to think it is accomplishing something. The alternative is periodic walnut-shell blasting to remove carbon buildup from the back of the valves, which is a pretty complicated and expensive process from what I have gathered.
I have never heard it discussed as an issue for port injection engines in general where the fuel works as a solvent to keep the valves clean, nor for the 4Runner in particular. I think it is a solution looking for a problem in this application.
