Oil Cooler line leaking coolant post TB job on a 04 V8
mastee
After the TB job, I noticed that I had forgotten to slide the clamps on the L shaped rubber hose just behind the oil filter and coolant was dripping from the bottom end of the hose, was able to squeeze a needle nose at an odd angle and slide the clamp back, it stopped but then the top part of the L shaped rubber hose started leaking, I tried adjusting the clamp, even put a second screw type clamp on it but that did not help.
Last night, I ended up draining the radiator, removed the fans shroud and the fan (glad to have used antiseize on those nuts) that allowed me to remove the L shaped rubber hose, there seems to be no rips or gouges but I do see couple of cuts on the very edge past where the hose clamps are placed ,is that the culprit or can there be some other reason, can the oil cooler be blocked somehow creating back pressure?
Should I just install the L shaped hose again, maybe get new clamps and and give it a go or replace it, is it possible that there is a tear I am not seeing that leaks under higher pressure?
can I use a regular hose from the auto parts store if dealership does not have it stock, it has a L shape?
Sorry for all the questions, I really need to get this out of the way
this one, its stamped 040424
Sent from my SM-N910V using Tapatalk
The dealership did not have it stock, so I ended up putting it in with new screw type clamps, they are narrower so I put two on each side and no more leaks, I refilled the coolant and drove around the block with the Heat on high and fan on full I shut the engine off as the temp was climbing and my live data showed 220 F but I am not getting any hot air from the vents I usually do not see more than 200ish, so is my new toyota OEM T Stat bad?
btw I had marked and made sure that jiggle valve was pointing up
Yes a hose from the auto parts store will do just fine. Buy a Gates one if they have it. Not sure about your thermostat. You say it's new. You sure it's not the coolant level. Did you drive it long with the leak? Hope your water pump is ok. If it doesn't cool down it's either your coolant level, thermostat or water pump usually.
Sent from my Pixel using Tapatalk
Jhunt
