I have a 2010 Tacoma and I use OEM oil filter 90915-YZZD3 on it.
would the OEM oil filter 90915-YZZD3 also work for my 98 4Runner ltd. V6, 3.4L?
I was thinking if it works, I could just buy a case of the oil filters
:thanks:
90915-20004 is a Japan made filter. 90915-YZZD1 is a smaller V6 filter. 90915-YZZD3 is the equivalent in size to the 90915-20004, which is the V8 filter. D1 and D3 are same, except the D3 is a bit taller than the D1.
Sorry to say as all the others but you defiantly can not use that filter on your 98.
I'm confused.
I have a case of D1 for the 4runner and a case of D3 for the Taco. It's no big deal. Those cases only last 50k miles. I'm on my second case for the Taco.So the 90915-YZZD3 filter will fit but it will be tight, is it safe to use?
I just don't want to buy 2 whole case of different filters, if I really don't have too.
So the 90915-YZZD3 filter will fit but it will be tight, is it safe to use.
Get one of those fitted caps that go over the end of the filter with the 3/8" socket hole in the end. Fits snug, turns off easy...
Just make sure you don't use it to tighten the filter, d'oh!
