Oil filter standard/larger?
Dasanii19
In regards to my 08' sr5 4x4, why is there a stock size and a larger size oil filter? Does one have benefits over the other?
Also, I still have a bunch of crush washers from my old car (07' Honda civic) which are factory. Will these work on my 4runner?
IDK about the Honda crush washers...
As far as a bigger filter goes it's a mixed bag. I like them. Many will fire back "Toyota put a gazillion dollars into designing this thing, why mess with it, why risk having to battle a warranty issue."
The challenge with bigger filters on the V6 4th gen is the filters have a tendency to drain out after a long sit. This means, especially with a bigger filter, there's a delay in building oil pressure. The PL20195/PL25230/FL400S size seems to be a good compromise and they have good anti-drain characteristics. The FJC guys have tried the PL30001 size and it seems to be too big, too long to refill after a long sit. The good of bigger filters is more media, more capacity etc.
I am running an experiment with some filters that have standpipes. I like the Baldwin BT215, Fleetgaurd FL700, Napa 1460 and the Napa 1806 so far. Lots of filter, no delay on the oil pressure light going out.
http://www.toyota-4runner.org/maintenance/68152-larger-oil-filter-1gr-fe-4th-gen-v6.html
The bigger filter is for the V8 and the V6 also comes with that one installed.
Not sure about the Honda washers... but aren't those aluminum? The Toyota ones appear to be a fiber composite type.
I just got back from wally world and pep boys. I picked up 6 qts. of 5w30 Mobil 1 full synthetic and the Purolator proline PPL10241, should I be good to go? my 4runner is a 08' sr5 V6 4.0.
And yes, the crush washers I have look to be aluminum, should they work ok?
Also, I was pretty surprised to see these Purolator oil filters at such a cheap price ($3.00 ea.), before I install this filter can you verify it is a quality filter? Also, the oil filter says nothing about being used with synthetic oil, I thought when using synthetic oil you needed to use a filter that accepted synthetic oil? not true?
And yes, the crush washers I have look to be aluminum, should they work ok? If the same diameter then yes, they'll work fine.
Also, I was pretty surprised to see these Purolator oil filters at such a cheap price ($3.00 ea.), before I install this filter can you verify it is a quality filter? Also, the oil filter says nothing about being used with synthetic oil, I thought when using synthetic oil you needed to use a filter that accepted synthetic oil? All filters will work with synthetic. The question is do you want to run beyond 7.5k with the filter? As a rule: Synthetic media, synthetic oil is good for a long OCI. If you don't have both stick with a 5k or very close to 5k interval. not true?
:cheers:
Not likely, but as CJ said, check the diameters. Mfgs tend to be consistent on things like this to minimize inventory...our '06 CR-V uses 14mm washers so it's likely the same with your Civic. The 4R uses 12mm washers.
-Brent
