Just do it yourself, it's not that hard. Use Mobil 1 and a quality filter, I like the Mobil 1 filter and it is a bit bigger so I can fit a little more oil. Draining and filling the oil is easy, though I recomend removing the skid plate or it will get covered by dripping oil. The filter is the PIA, remove the driver side front wheel and unclip all the plastic guards. The filter is towards the bottom front of the motor. You will need the type of tool that goes onto a ratchet as there is no room to work, a rubber piece for grip works as well.
