MDST
Member
Maybe somebody have posted this. This is a very good info to use as a reference for Toyota applications:
Cruiser Outfitters
Cheers
Cruiser Outfitters
Cheers
Correct me if i am wrong but they have the 881's and 882's as the same spring rate.
My understanding is the 881's and 883's are the same (883's are just longer) and the 882's are designed for the additional weight........
880, 881 and 882 have the same spring rate, same bar diameter ( 16 ) but different heights. 880 = 365mm, 881 = 375mm and 882 = 395mm.
881 and 883 are equals in hight but 883 have a higher spring rate and bar diameter ( 17mm ).
With 883 more height is achieved in the truck because it supports more weight. 883 is only if you have heavy bumper and winch I think.
Cheers
Quoted from the Lift info sticky
880 1" lift coil for stock weight.
881 2.5" lift coil for stock weight.
883 3" lift coil designed for 100 lbs. additional front weight.
882 3" lift coil designed for 150+ lbs additional front weight.
this shows the 882's to be the heavier weighted spring.
