OME 60073 Rear Shocks - up to how much lift?
HiluxSurf SSR-G
Senior Member
Hi,
What's the maximum lift that the OME 60073 rear shocks can handle? I think it has an extended length of 21.61 inches. Can it handle up to 3" of lift? What about 3.5" of rear lift?
Thanks.
The bilstien shocks advertised for 0-2" of lift is 20.8 extended. Which is basically stock length and I ran them with OME 890s. So your good up to 2.5 inches and I say you could do 3"
However id recommend getting the Landcruiser shocks. Its very easy to run them and give roughly 10 inches of rear travel. 23.7??? extended I believe. Also they are cheaper than the OME id imagine. From the dealer they are 45 a pop. If your interested PM me and ill tell you what you need to run them. Its all bolt up, everything total cost me 210 bucks
I ran the LC Shocks with 7 wraps and with 99 Talls with a 1.5 inch spacer. The ride was really nice. I would run it again for sure if I didn't just score a whole OME kit for 400 bucks.
DJNutshell
