Ome 891 vs 861?
Desert36
I've got the 891's now and there is rear sag getting worse, the front is 5100's on the max notch, not sure on the spring. I was gonna use the land cruiser front shock for the rear. I carry at least a couple hundred lbs of trail parts & tools.
Was thinking of using the 861's for a fix to my sag.
Anybody have this combo with 33's?
Have you considered the Superflex coils from toytec?
I have over 200lbs of stuff in the back of mine and it sagged with 890's. Swapped out the 890's for the superflex along with 2 10mm trim packers per side and I got about 3.5'' of rear lift.
Just another option.
Thanks, the only thing I'm worried about is if I'll get the same flex with 861's or if it will be more prone to tipping over, I'm one wheel off the ground a lot.
EnviroHokie
