OME BP-51 Suspension System -- Anyone yet?
Help me out guys... Has anyone bought the OME BP-51 System for the 4Runner?
None that I have seen yet, but I wouldn't mind being the first! I need to find a money tree first though, but the product pretty much has me sold at this point. There will be ALOT of research time before I do decide to pull the trigger....
I want them also ,just not sure if the kits that are currently available will work with my kdss
I'm going by memory, but I believe OME typically uses a shim or something similar for KDSS vehicles. That may not be necessary with the threaded body which can be used to make the adjustment. That would leave the only KDSS potential question to be mounting of the reservoir/bracket, which I believe FOX had an issue with that required some custom modding. So who's going to pull the trigger first?
That resi mounting of the bp-51 is what I was concerned about and not wanting to have to mod brackets for the resi on the driver side. Also there is not much info on adjusting the preload as OME recommends using an adapter and a wall mounted spring compressor to adjust height . Poss due to the aluminum body n not galling the threads. Been trying to get info on fj and LC 200 forums as only a few people have them . Also checked on the prado 150 series and ARB Europe states that I need bp519004L and fit kit ending with a 9 vs 8 with kdss . Because the 4Runner is based on prado 150 suspension. Can't find it on the ARB USA or Australia sites .
But as far as the feedback from those that have them both fj' sand L/C 200 say they ride great on and offroad and having individual adjustment of compression and rebound plus the bypass technology has been very impressive . Just trying to be patient and wait for them to b available for my specific application .
I'll most likely have it sooner than later. Just need to decide which UCAs to pair with them.
Doesn't require any additional components, the system is designgned around stock....the kit also includes reservoir brackets
Who is selling them stateside?
Main Line Overland Main Line Overland Ask for Pete or Matt, tell them Pat sent ya!
Yes...will work with both KDSS/non-KDSS...I just think you need to specify.
Resi mounts included
Thanks Pat! I used to live down the street from that shop & know of them. I'll hit them up when I'm ready to buy.
I couldn't agree more...there are a few members here that have used them that were pleased.
As an update I did talk to Matt, an owner a Main Line Overland, and he said he will talk to our local ARB rep about a possible group buy, if there's enough interest. That sounded like a winner to me.
I'm in!
BillM777
