OME Nitro Front Shocks=stock height perch ?
Greydog
Member
Hi, does anyone know if the spring perch on the Front Nitrocharger shock that OME uses are the same height as a stock shock ?
I am shooting for a 2 inch lift and want to use these shocks, but not the OME springs (which would get me to a 3" lift).
So I guess the question is whether the Nitro shock alone provides any lift ?
Thanks for any thoughts/experiences.
Shocks control rebound, springs control ride height.
Would also help to know what year vehicle it is.
Are you using a taller coil to achieve this 2" lift?
As fourwd1 said.
I'm 90% sure that all replacement shocks have the spring perch at the same height as stock with the exception of the Bilstein 5100. The 5100 does have 3-5 different settings to set a different ride height.
